Taking toploader shifter out
Old Apr 10, 2006 | 01:16 PM
rmalottwtes30's Avatar
rmalottwtes30
How do you get the shifter out of a toploader? Or can you? If you can and when you get it out will it mess things up inside for when you put it back together? I am putting a np435 in and figure if I take the shifter out it should be easier. Also how big of a hole should I need to cut to accomidate the shifter? Thanks for the help guys. Ryan
Old Apr 13, 2006 | 09:32 AM
piperig78's Avatar
piperig78
np435 handles come out its springloaded and hard. press down on the top of the base and turn a 1/4 turn to the left it should pop up. then pull it out.
Old Apr 13, 2006 | 03:06 PM
z537z's Avatar
z537z
Quick note: Top of the bezel, not the shifter.
Old Apr 13, 2006 | 06:14 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
if found a heavy pair of gloves works well, if you cant get it with that, you can use the ends of some channelocks
sometimes they can be stubborn
markthompson999
Apr 22, 2012 04:32 PM
wastedmoneyproject
Aug 11, 2011 07:31 PM
brandonwsmith66
Nov 25, 2008 07:53 AM
branpollard
Jan 24, 2005 10:23 PM
inliner
Dec 19, 2001 06:26 AM
