View Poll Results: 300 or 302?
rebuild my 300?
28
90.32%
get a 302?
9.68%
Voters: 31. You may not vote on this poll
rebuild or 302?
Old Apr 11, 2006 | 08:15 PM
309Ford's Avatar
309Ford
Putting a 302 in a truck to replace a 300 is going backward. Torque makes a truck motor, and the 300 has it. The 302 will downshift far more often when hauling a load and that isn't desirable in a truck used for work.
Add some breathing mods while retaining the low speed torque and you'll have a vastly superior motor to a 302. Try headers, a Holley 390 and a DP intake and you'll be quite pleased with the results.
Old Apr 12, 2006 | 11:24 AM
BurleyOne's Avatar
BurleyOne
I would stick to the 300. You propbably don't have the skills to do a total swap.
Old Apr 12, 2006 | 11:28 AM
1983_f100's Avatar
1983_f100
wow...thnx alot for the info on everything ill look into some of it...
Old Apr 13, 2006 | 12:08 PM
1983_f100's Avatar
1983_f100
stupid question...cant i just get an intake from autozone that would fit my 1 bbl carb?
Old Apr 13, 2006 | 06:14 PM
309Ford's Avatar
309Ford
The motor would still be breathing through a one barrel straw. My truck, when stock with the one barrel, would do 82 mph on a flat road, top speed. This with 31 inch tires and 3.55 gears.
Same truck, same gears, can be going 82 mph UPHILL and still have good reserve acceleration after modifications. Top speed is at least 15 mph faster (my speedo isn't accurate past 85).
The carb, intake and exhaust are all restrictive. If you don't replace them all you won't see much improvement. Air's gotta get both in and out.
If you want even more horsepower and don't mind the loss of some low speed torque then headwork and a cam are needed.
Old Apr 13, 2006 | 06:38 PM
andym's Avatar
andym
OK, who voted for the 302 in the poll? I see an FTE beatdown coming...
Old Apr 13, 2006 | 07:00 PM
1983_f100's Avatar
1983_f100
haha..i was thinkin the same thing..thnx for all the help guys and im just gonna save up and get the holley 390 4 bbl carb...
Old Apr 13, 2006 | 07:17 PM
Col Flashman's Avatar
Col Flashman
You've to make the 300c.i.er BREATHE 1st & Foremost, if you do not, you accomplish Nothing but Flushing the Rhino you've just invested.
You'll need to find an Offenhauser D/P Intake, then fit a 390-500 CFM Holley Carb. & then a 2-into-2 Header that suits you, such as a Hooker, Hedman, Borla, etc., then 2 1/2"-3" Exhauste Pipes (my preference is 8' of pipe that goes clear back to the rear bumper) into Magnaflows for best results from just Bolt-on Performance Parts.
Old Apr 13, 2006 | 07:30 PM
Col Flashman
You've to be Daft if you believe Anyone here would Opt for a buggering 302 v8 to but in one of our trucks, Bleedin' Daft I state.
Old Apr 13, 2006 | 10:10 PM
desperado_18_2000's Avatar
desperado_18_2000
Definately don't put a 302 in there. I don't want to harp on anything anyone else has told you but they do not make a good truck engine. I've had one in an 82 F-150 swb and that thing was a dog. Well, when used for actually work it was anyway. It'd tear up the blacktop anytime i wanted...but it was absolutely worthless when it came to towing, hauling or anything else.
I'm going to be building up and replacing the engine in my rig in a few months, so it looks like we get to learn together eh?
Old Apr 14, 2006 | 12:48 PM
1983_f100's Avatar
1983_f100
thats what it sounds like...i think what im gonna actually do first is to invest a the holley 0-8007 carb and then go for some exhaust...
1979 300i6
18
Feb 16, 2020 02:19 PM
Jcabodi
Mar 10, 2017 12:53 AM
easyridin
Aug 27, 2015 06:06 AM
ford_0004
37
Jan 16, 2011 06:31 PM
