Strange electrical problem
Old Oct 17, 2002 | 10:01 PM
390fe's Avatar
390fe
This is on my 1970 F100. At idle with the headlights off, the tach and lights in the cab go nuts. Turn the lights on, and everything calms down. Any ideas? My first thought is an intermittent short at or near the light switch assembly. I'll know more Friday afternoon.
Old Oct 17, 2002 | 10:44 PM
gtex's Avatar
gtex
Sounds like the pot that dims the interior lights is shorting when the light switch is in. Have you repeatedly dimmed and brightend the interior lights, making full turns of the dimmer switch? This somethimes helps clean it up some. Alot of times these dimmers don't get used much. I forgot mine was even there for a while. Now I try to use it frequently so that it makes a decent contact.
Old Oct 17, 2002 | 11:04 PM
sparky's Avatar
sparky
Could it be the voltage fluctuating from the alternator,and when you apply a large load the regulator "calms down" ?????
That is if you mean lights flashing dim to bright, and electric tach bouncing.
Sparky
Old Oct 18, 2002 | 08:26 PM
HighBoyGirl's Avatar
HighBoyGirl
Old Oct 19, 2002 | 07:44 PM
390fe's Avatar
390fe
It turns out the problem was one of the two power wires for the stereo. As soon as I unplugged it, the tach settled down. Darn stereo doesn't have any speakers at the moment, so no harm in pulling the plug.
Frankiec#1
Feb 15, 2021 09:47 AM
brent1204
1983 - 2012 Ranger & B-Series
Mar 26, 2014 10:57 AM
abyars111
Nov 12, 2012 09:18 AM
tjdad62
Aug 19, 2011 05:42 PM
JNKDad
Dec 22, 2007 06:22 PM
