If I knew back in the summer that Ford puts junk ball joints in thier trucks I would've taken it in to the dealer then. But I thought it was just an alignment/balance issue and not a warranty issue.
Should have joined FTE sooner...and been reading up. You would have found out really quick that the ball joints are a weak link. Sorry to hear that you missed your warranty period. That is a bummer!
I just bought my 99 F250SD PS CC Lariat with 176k on it. Appears a couple are bad. I purchased the NAPA Gold (the good ones) with zerts (moog). Replacing all 4 this weekend 11-04-06. When I bought this truck a buddy of mine that is a certified Ford mechanic said the ball joints and the tranny are the weak links.
Several months after waranty expired the front end on my F250 started making a loud squeeking noise while turning the steering wheel. Dealer says its the ball joints. Quotes me in the neighborhood of $1200 to replace. Seems kind of steep to me. Also bugs me that the ball joints on what is suppsose to be a heavy duty truck lasts just over 36,000 without having to be replaced. It was not like I was beating the crap out of them on a lot of gravel back roads or anything.
My moog joints end up with the uppers breaking off their grease fittings because of the 4x4 axle. I'm not really sure what to do about it either. I greased them when they went on and then never again after I used 4x4 the first time. So far I have 17,000 on them. No squeaks or wobble yet.
The Moog ball joints mounted in upper position must be greased and then zerk replaced with a plug. To grease again, you have to reinstall the zerk, grease, and then reinstall the plug(s). Kind of difficult, but beats the alternative--ball joints that cannot be greased at all.
Just so you know... I totally knew that (he said foolishly).
The current plan for tomorrow is to go out and pick up a new fitting and a plug. The fact that I didn't think of that 2 months ago is why I LOVE THIS SITE!
The NAPA ball joints .... the upper came with a 45 degree grease fitting, that I was able to grind down, and it works fine in place.
Back in mid-summer, I noticed that my '04 F250 4WD Lariat seemed to be riding rough and wasn't tracking very straight. This is my first Ford and my first 4x4 so I wondered if I was just being too particular. At the beginning of July, I had just reached 35K miles, so it never even occurred to me to consider the ball joints. I've had a very busy summer and I finally got a chance to get my truck into the shop for an alignment last Fri (Oct 27) at 28,400 miles. The shop manager called when he got it on the rack and said that the left upper ball joint, two lower ball joints, and the pitman/control-arm joint were worn out.
I was so stunned, I stuttered in reaction. He said he understands my shock, and that he has seen many low mileage Ford trucks in with bad ball joints. He said they're simply under-engineered for this application.
Looks like a $500 to $600 repair. I invested in the Superduty to avoid this very kind of early repair issue. I wouldn't mind if I were 5yrs/80K into ownership of this truck, but 2.5yrs/38k with bad balljoints is very disappointing. Is this what they mean by "Ford Tough"?
The shop I took it to Oct 27th was a independent alignment shop I've used for years. The shop manager suggested that I try to get Ford to replace these ball joints since the warranty period is only just passed, and ball joints don't wear-out in just 2K miles. So I called Ford Motor Company Customer Relationship Center and spoke with a representative, Tammy. She said that first, a Ford authorized shop would have to determine if the ball joints are bad. It's a rainy day here in Memphis, so I finally got my truck into the Ford shop this morning. The service advisor said that their Front-end Tech checked it out and everythig seems fine. Nice and tight. I get the feeling that Ford and associates are circling the wagons here to avoid replacing thier crappy ball joints under warranty. Why get get into a "Sorry, you're just out of warranty range" arguement, when you can get the Ford shop tech to claim there's nothing to fix.
While it's in the shop, I'm having one of their 'Golden Diesel Techs' attempt to address the issue of the low power followed by 'pa-put, pa-put' at highway speeds (65-70mph). And since I had the series of recalls done about this time last year (CAC Duct,Wiring Harness,Reflash), I've had less power and fuel milege dropped about 2.5mpg. I wonder if there's a liability-lawyer attached to the diesel tech's hip, too.
When I get my truck back, I'm gonna jack up the front and give the wheels a shake for myself.
Changed mine out for the first time at 131,000 with Moogs. I only had very slight play on the pass upper the other three were fine but I replaced all of em along with my sway bar links and shocks. And I still have a rattle
