Sponsored by: Real Truck
View Poll Results: Have you replaced your ball joints?
once
104
35.49%
more than once
19
6.48%
will be replacing soon
48
16.38%
have not replaced, zero problems
122
41.64%
Voters: 293. You may not vote on this poll
Ball joint poll
Old Apr 21, 2006 | 07:16 AM
  #46
nosdog2's Avatar
nosdog2
Sure here you go guys! Not sure if they are a sponser or not, but if it gets taken down or re-directed I will be happy to PM it to you.
Part # 4WDBALLJOINTKIT
Price $230.94
http://catalog.powerstrokeshop.com/p...tegoryID=84614
Old Apr 25, 2006 | 09:02 AM
  #47
warrior183's Avatar
warrior183
I just installed this same kit on Saturday 4/22/06. They are coming from Wabash Ford in Indianapolis.
2000 V10 4x4 4:30 88,000
Stealership did drivers side lower about 10k ago along with a full brake job and alignment. Passenger side lower was starting to go so I opted to replace all 4 with the MOOG kit myself. Upper grease zerk is 90 degree, but still too close for comfort. MOOG instructions state to remove it after greasing and re-install plug.
Passenger sider lower sealed bearing hub bolts were totally rusted! not fun! 7 ton puller and a big sledge hammer, so then I replaced the bearing too at $320, 4 wheel ABS.
You absolutely will need a seal installer tool, you can make one or buy one, but you will need one. You will also need a ball-joint press. If you replace a sealed bearing hub unit, also buy new stud bolts. Getting the old ones out is NOT easy, but all of my dealership mechanics and parts counter workers were on strike so I couldn't get parts.
I also opted to replace U-joints while I was in there. I also painted the hub studs with anti-sieze at re-assembly should I ever need to go back in there.
If the hub studs weren't rusted in so bad it really wouldn't have been that bad, but living in Minnesota, rust is everywhere.
Good Luck
Old Apr 25, 2006 | 06:52 PM
  #48
StaJs's Avatar
StaJs
2001 SC was starting to pull to the right @ 120000 miles, tires leaned in at the top and was starting to wear on the inside edges. Top joints shot - replaced with moogs myself. I have a ball joint press but the cups were too short so I cut some new ones out of house jack pipe. Made the seal driver out of pipe and flange. After one side was done and all the tools made up the other side went much smoother.
Old Apr 27, 2006 | 08:34 PM
  #49
Ford850's Avatar
Ford850
where can you buy a seal installer tool?
Old Apr 28, 2006 | 05:37 AM
  #50
sportscar's Avatar
sportscar
Dealer replaced all four noisy front end ball joints at 18,000 miles!!! The truck is an 04 4x4 used for light towing. We did have lots of salt last winter, but Damm, 18,000miles/2 years?!
Old Apr 28, 2006 | 06:17 AM
  #51
kenneBF250V10's Avatar
kenneBF250V10
Make your own, cheap and easy. Click on this link and scroll to the bottom, there is a list of what you need and a picture of the assembled tool. I wish I'd have seen this before I done my own balljoints. I ended up taking my axels to a Ford dealer to have the seals installed, luckily they didn't charge me.
https://www.ford-trucks.com/forums/s...ht=ball+joints
Old Apr 28, 2006 | 09:32 PM
  #52
vtmdsm25's Avatar
vtmdsm25
Oasis?
[QUOTE=biz4two]According to an Oasis report the upper and lower ball joints were changed at 35,400 miles in 2004...which is right before the warranty.
What is an Oasis report? How do you get one?
Old Apr 28, 2006 | 09:53 PM
  #53
mrpotatohead's Avatar
mrpotatohead
I am curious as to what noise if any was heard from the bad ball joints. Did the noise go away after the joints were replaced?
Old Apr 28, 2006 | 10:04 PM
  #54
99f350sd's Avatar
99f350sd
When you hit a bump usually you will hear a clunk....
Dick
Old Apr 28, 2006 | 11:01 PM
  #55
warrior183's Avatar
warrior183
Jack up one wheel at a time. Get a good hold on the wheel, cradling from the bottom with both arms, pull and lift toward you and up. If you hear or feel any slop, or clunk, their done.
My reccomendation, is to replace all four plus u-joints with MOOG greasables when the time comes. Then hopefully you won't ever have to do it again.
Old Apr 29, 2006 | 08:05 AM
  #56
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I had mine replaced about every 25,000-30,000 miles. Was on its 4th set when I sold her, and was probably needing replacement again.
Mine saw very dusty conditions, and regularly had to ford through water.
It is the records Ford has of all your warranty/recall work on your truck.
If you want one, just speak to your local friendly dealer.
Old Apr 29, 2006 | 09:02 AM
  #57
dcf4x4's Avatar
dcf4x4
I just had mine replaced on my 350 4x4 at 82,578. Not sure of the past history on it.
There is a company that provides complete front axle upgrades to specifically address all these problems. Can't remember the name but the cost of 2 grand and change was just to far out there for me.... until I started tallying up all the repairs of balljoints and bearings.
My general policy on this truck has been to always replace with heavy duty aftermarket but a complete axle change is out of reach right now.
Old Apr 29, 2006 | 04:20 PM
  #58
jlande's Avatar
jlande
Had the dealer replace them at 74,950 miles, covered under my 75,000 ESP.
Old May 7, 2006 | 08:33 PM
  #59
mostoyzwinz's Avatar
mostoyzwinz
upper right at 40k mi.
required reading before doing your BJs yourself is racerguy's nice write up.
https://www.ford-trucks.com/forums/s...d.php?t=354091
Old May 7, 2006 | 11:12 PM
  #60
pclark76's Avatar
pclark76
Lately noticed a clunk when I hit a pothole just right. Figured I better check everything in the front end. Ball joints gone, 2 out of 3; did not even check the fourth one, just bought all four. Truck has just over 216k but it is an oddball to this site - 2WD. Went ahead and bought new Hawk brake pads and Powerslot rotors to do it all at the same time while it is all broken down. And no, never had any rotor problems, but one rear brake hung and wore down to the backing and scored the rotor bad and I just put a set of cheap Autozone pads on in a hurry to get me back running.
