Offroad & 4x4
Conecting points when stuck.
Old Apr 7, 2006 | 08:43 PM
busted knuckle's Avatar
busted knuckle
ive done it. maybe shouldnt do it but if your stuck and its cold and raining/ snowing, you wrap that chain around the 1st thing you see.lol
Old Apr 8, 2006 | 07:17 AM
Pkupman82's Avatar
Pkupman82
I have pulled vehicles from the swaybars before, just have to be careful not to rip the stupid thing off. Who needs a damn swaybar anyway, I don't have em on my rig! More flexy that way
Old Apr 8, 2006 | 09:48 AM
monsterbaby's Avatar
monsterbaby
well the tow straps work so much better for getting you unstuck kinda like a rubber band they will just ****** you out were a chain just jerks things I just don't understand why people still do that. For attaching points you can buy what they use to tie vehicles down on the transport rigs that looks kinda like a T on one end and has a hook for a chain on the other side these go into the oblong shaped hole in the frame then turn 90 deg to lock in so your actually pulling directly on the frame. And all vehicles have those in the frames even tractors have them (atleast john deere's do because they make you use these hooks when you haul the tractors out of the factory and won't let you hook to any other place on the tractor) If those are strong enough to legally hold a 20,000lb tractor I think they will hold most of our trucks in a pulling situation. And if your worried about tweaking the frame put one on each side with a chain connecting them and hook to the chain which will pull both frame rails.
Old Apr 8, 2006 | 08:41 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Well...from what I've seen...a chain does a lot better job of getting trucks unstuck. I've personally whitnessed countless occasions of the truck doing the pulling, get dragged back to the stuck vehicle after giving the strap a jerk.
A chain will apply a larger force than a strap. It's simple physics. Its like putting a spring between a hammer and a nail...you wouldnt do that would ya?
Plus, when a chain breaks, it usually doesnt fly around as much as a strap does. A strap can shatter windows, dent tailgaits, and decapitate people.
Example: The strap didnt do anything but pull the other truck backwards. So now, he is bringing out the chain. Jerking with the chain moved him about 1', whereas the strap did nothing. It later took a 4x4 tow truck with dual 15,000lb winches chained to a tree to get him out.
Old Apr 8, 2006 | 09:40 PM
MBBFord's Avatar
MBBFord
So are you saying if a chain breaks, you won't get any damage like that.
I've seen a back window break, dent and scratch the hell out of a tailgate, and rip bumpers off many atimes.
Old Apr 9, 2006 | 07:07 AM
tjc transport's Avatar
tjc transport
i ain't rite
well, the main thing i see wrong with that picture is all the mud. when trying to unstuck something you want to be sitting somewhere you get traction, like on firm dry ground. if you start out in mud or wet slop, all you are going to do is spin your tires. and maybe get stuck too
Old Apr 9, 2006 | 09:42 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
chains are one of the most dangerous things you can use for extraction, they will destroy you or your truck just like a winch cable.
the only thing i can htink of more dangerous is the straps with the metal hooks on the ends
straps are the best method to extract a vehicle....less damage to frames and tow points, not to mention your back and neck
Old Apr 9, 2006 | 11:32 PM
mustange70's Avatar
mustange70
As KO and others have stated, straps are way better for pulling out stuck vehicles, as you can take a run and jerk the vehicle without fubaring the 2 vehicles, if you're worried about the strap slingshoting on you, wrrap it with a weight, and actually a smaller lenght of chain work well, right in the center of the rope. Now in order for this to work properly you have to have a vehicle of similar weight, as a lighter weight truck will not have the momentum to pop the stuck vehicle out.
Now as per the pictures posted by ATC, well i can see a couple things, 1. that strap in the picture is not big enough for the weight of the stuck ford for the strap to work as its designed, it needs to be thicker and probably longer too.
thekingofcows
Dec 21, 2009 12:43 AM
inline6 Red Neck
Feb 1, 2007 11:59 PM
Greywolf
Garage & Workshop
77
Nov 18, 2005 01:46 PM
RussB
34
Oct 6, 2004 10:53 PM
airharley
Jun 24, 2003 08:35 AM
