Running Rich
Old Apr 1, 2006 | 07:52 PM
4x4-Ford-4x4's Avatar
4x4-Ford-4x4
Smile Running Rich
How do i check the float valve and make adjustmenst on a 1985 Motorcraft single barell carb for a 300 (stock carb... im not sure what the problem is ..
but my truck fumes black smoke out the exhaust at idle.. and runs like hell at low speeds... but is fine at high speeds.,. ..........also also where can i find a schematic diagram
Old Apr 1, 2006 | 07:56 PM
Ford_Six's Avatar
Ford_Six
Is that the electronically controlled carb? If it is, the problem is most likely the fuel metering solenoid. Also check the standard carb stuff, like the power valve, and make sure the O2s is plugged in, and that the throttle position sensor and map sensor are working.
Old Apr 1, 2006 | 08:05 PM
4x4-Ford-4x4
Red face
idk id it is or not
Brody Olson
22
Jan 8, 2014 10:46 PM
OrdoDraconis
Aug 27, 2013 09:04 PM
lildrummer420
Nov 23, 2011 06:57 PM
Madmechanic
Nov 4, 2007 09:45 PM
project supercab
Mar 7, 2006 01:09 AM
