New Carb.
Old Nov 23, 2011 | 12:08 AM
lildrummer420's Avatar
lildrummer420
New Carb.
Ok i am running my '86 F-150 with the stock feedback carb. Is there a carb i can upgrade to without changing anything? It is a 4.9 L6 4 speed.
Old Nov 23, 2011 | 08:36 AM
Galendor's Avatar
Galendor
The stock feedback carb works in tandem with the stock electronic ignition system. They work great together, but neither works very well on its own. So if one gets modified (altered) then the other is usually also altered.
Search for "DSII conversion" or "Duraspark conversion" on this site and you will find a wealth of information about this topic.
Old Nov 23, 2011 | 08:42 AM
Gary Lewis's Avatar
Gary Lewis
Assuming that by saying "upgrade" you mean that your truck is running fine now but you want more power, then the answer is no. You can't change out a feedback carb for a non-feedback carb w/o killing the power and fuel mileage of the truck.
That's because a feed-back carb is controlled by a computer, which also controls the ignition timing. If you change out the carb the computer figures it out and it will probably put you into limp-home mode, meaning that your timing is locked at something like 10 degrees. The truck will start ok, but your power and mileage will be gone.
The only way to successfully change out the carb is to also change the ignition system to DS-II at the same time. Search this forum for that and you'll find a lot of information.
Old Nov 23, 2011 | 08:43 AM
Gary Lewis's Avatar
Gary Lewis
Six minutes late. Good job, Galendor.
Old Nov 23, 2011 | 08:58 AM
Galendor's Avatar
Galendor
Well you big dogs with your porting, camshaft modifications, etc. are a bit out of my league, so I'm trying to help on the smaller stuff when I can!
To the OP, if your stock feedback system is working, there is some good reason to leave well enough alone. It should give you moderate, smooth power and good gas mileage to boot. But of course it is also understandable if you are just itching to do some modifications. There is a wealth of info here on what/how to do that.
Old Nov 23, 2011 | 06:39 PM
billt28's Avatar
billt28
About the only thing that I can think of, without doing a DSII conversion, would be to rejet the carb, but your just wasting gas then.
Old Nov 23, 2011 | 06:56 PM
Eightyfive Flareside's Avatar
I agree, i changed my intake and carb on my 86 to an Offy 4 barrel and a edelbrock, they are right, change the dizzy at the same time.
Old Nov 23, 2011 | 06:57 PM
BTW an offy intake isn;t cheap. but i didn;t want a 1 barrel anymore. So you might have to take that into consideration too. I spend about 550 bucks between that and the carb, and a newer dizzy will run you a good chunk too, unless you junk yard it and rebuilt it.
bbf150
Aug 11, 2011 12:05 AM
|WYG|SS
Nov 4, 2010 03:05 PM
fast_farmboy
Apr 18, 2006 11:49 AM
Steven D
Bronco II
Mar 25, 2006 07:58 PM
88bronco351
Bronco II
Oct 30, 2003 10:57 PM
