Door locks
Old Apr 1, 2006 | 03:53 PM
FDXFX4's Avatar
FDXFX4
Door locks
I have a 04 F150 Screw. When you drive the doors automatically lock. Is there a way to set them so when you turn off the truck it will automatically unlock as well.
Old Apr 1, 2006 | 05:06 PM
spiggy769's Avatar
spiggy769
Yes but it requires the use of your finger and the unlock button on the door...That works good for me
Old Apr 1, 2006 | 05:22 PM
Mr. PC's Avatar
Mr. PC
Don't they automatically unlock when you pull on the door handle?
PC
Old Apr 1, 2006 | 07:04 PM
Dazz's Avatar
Dazz
PC
If they didn't I'd still be sitting in mine.
Old Apr 2, 2006 | 08:18 AM
cullenkyla's Avatar
cullenkyla
you can fix them were they don't lock at all by using your message center on the
dash board
Old Apr 2, 2006 | 09:07 AM
FDXFX4's Avatar
FDXFX4
Your right the front ones open when you pull the handle, but the back doors don't. You have to pull the lock up before you get out or hit the button on the front seats. How do you use the message center to program them to not lock at all? I like that they lock, but I would like to have to have them unlock when it is put in park or when you turn the truck off.
Old Apr 2, 2006 | 10:11 AM
cullenkyla's Avatar
cullenkyla
The only way is lock or unlock in the message center just scan you will see it will say
auto lock on or off hope this helps
Old Apr 2, 2006 | 10:39 AM
newtuner's Avatar
newtuner
Did you check to see if there is a child lock button on the side of the door? I only have a two door so i don't know if ford does this.
Old Apr 2, 2006 | 11:05 AM
exiled's Avatar
exiled
its does work great. if the key is still in the ignition you can push the lock button and it will unlock also.
Ford uses the child safety locks but i dont know about on the pickups. i dont know why they would.nt all you have to do is look and see.
Old Apr 2, 2006 | 11:38 AM
carmk's Avatar
carmk
There is a way to make this happen. I cannot recall the page, but it is in the owner's manual. You have to go through a series of steps in a certain amount of time and the correct sequence for it to make the change. Take a look at your owner's manual...good luck.
Old Apr 2, 2006 | 01:10 PM
GordoPanocho's Avatar
GordoPanocho
Actually, I don't believe there's a way to make this happen. Search these forums using keywords like LOCKS BACK SEAT, etc. and you'll see that this has been discussed on several occasions.
tomwolters500
Sep 2, 2012 07:28 AM
rsisneros
1997 - 2003 F150
Aug 26, 2008 09:03 PM
Grayrock
Electrical Systems/Wiring
Feb 22, 2008 07:15 AM
Pkowis
Jul 27, 2007 03:35 PM
twister428
Mar 4, 2005 06:35 PM
