Wierd noise when power locking door
Old Feb 18, 2008 | 11:51 PM
Grayrock's Avatar
Grayrock
Question Wierd noise when power locking door
My '03 F-150 SuperCrew just stated making a loud noise when you lock the doors with the keyfob or the door panel button. The doors lock and unlock OK, it is just the drivers side door that makes a loud noise when you lock it with the fob, switch or when the automatic lock activates when you first put it in gear and accelerate. I searched a lot of threads here and saw none that were similar. Lots of door locks failing, but mine are working (for now). Is this a preliminary stage before they fail?
Old Feb 19, 2008 | 05:28 PM
Franklin2's Avatar
Franklin2
Keep an eye on it, it could be the beginning of the end.
Old Feb 20, 2008 | 12:25 AM
Grayrock's Avatar
Grayrock
Any idea how to fix it?- it is quite loud and startling.
Old Feb 20, 2008 | 10:23 AM
Franklin2's Avatar
Franklin2
New actuator would probably solve it?
Old Feb 20, 2008 | 01:20 PM
Grayrock's Avatar
Grayrock
So where is a good source and what should I expect to pay?
Old Feb 22, 2008 | 07:15 AM
blue beast's Avatar
blue beast
A bit of white lithium on the inside lock mechanism and a bit of silicone on the actuator
itself could help it if it is extra strain induced, Or you could spray the window and door
with a hose (like rain) and then open up the door and see if water is entering and getting in the actuator, This is a big problem on the Fs broncos. The rubber boot gets
torn on the actuator and the door seals leak a bit and of course there is a rod for the
water to follow right into the Actuator. Lift the boot and a quick spray with silicone
then liberally spray the outside of it.
jo15765
Sep 6, 2013 10:15 PM
rc3
May 24, 2007 12:18 AM
trike1946
Electrical Systems/Wiring
Sep 17, 2006 09:13 PM
cowboylukas
Aftermarket Products
Jan 2, 2006 03:56 PM
Qman_1
Jun 25, 2003 04:58 PM
