No boost when cold?
Old Apr 1, 2006 | 11:12 AM
popkorn's Avatar
popkorn
No boost when cold?
No boost pressure,started up cold and let warm up a little. Tried to take off and no boost psi [have gauge] truck would barely move. Turned off and restarted everything was fine. It has done this about 5 times in the last month.
Old Apr 1, 2006 | 11:15 AM
Kwikkordead's Avatar
Kwikkordead
Your exhaust back pressure valve is sticking closed. You can unplug the solinoid that runs it at the front base of the turbo. It will default to the open position.
Old Apr 1, 2006 | 11:47 AM
popkorn's Avatar
popkorn
Can you just leave it unplugged? Is that the same solinoid for warm up? I can hear it through the exhaust when its cold. I have had that stick on before [really cold out] sounds like an exhaust brake. but truck would still go. This problem I have now seems different, no power no noise
Old Apr 1, 2006 | 12:40 PM
Kwikkordead
Hmmmm, is your wastegate lever connected to the canister rod at the top rear of the turbo?
Old Apr 1, 2006 | 12:49 PM
bloomy63's Avatar
bloomy63
is there any smoke black, white, blue?
Old Apr 1, 2006 | 12:56 PM
popkorn's Avatar
popkorn
yes wastegate rod and canister is connected. Yes black smoke and high egt trying to drive it very far.
Old Apr 1, 2006 | 01:01 PM
Kwikkordead
Remove the air boot from the intake of the turbo and see if it's stiff to turn or if the shaft wiggles side to side or in and out. If you get much more than a hair's breadth of movement you need to rebuild your turbo.
Old Apr 1, 2006 | 01:10 PM
popkorn's Avatar
popkorn
Just installed wicked wheel last weekend,turbo felt good. Had problem before and after wheel install.
Old Apr 1, 2006 | 03:01 PM
Kwikkordead
Have you tried it at the stock fuel setting?
Old Apr 1, 2006 | 04:20 PM
CAT_man_963's Avatar
CAT_man_963
Hmm... the EBV sticking closed will make the EGT's high - but I don't think that accounts for the black smoke.....
I'd probably unplug the solinoid like Kwik suggested, just to rule that issue out....
Old Apr 1, 2006 | 11:33 PM
popkorn's Avatar
popkorn
Yes removed tuner to loan to a friend was the first time it happened. will try unplugging the solinoid just to be sure. thanks guys for your help!
boomerang50
Modular V8 (4.6L, 5.4L)
May 20, 2014 10:40 PM
Km1210
Jan 5, 2012 12:53 AM
davinci69
Mar 14, 2011 10:30 PM
muddrag1
Oct 31, 2008 01:40 PM
dogman
Nov 14, 2007 06:57 PM
