MAX Boost
Old Nov 11, 2007 | 11:15 AM
dogman's Avatar
dogman
MAX Boost
What is the max boost before the heads or head gaskets pop? I was in a little bump to bumper race and I boosted up to 38 to 39 pounds boost. I did backed off. But I was wondering......
Old Nov 11, 2007 | 11:51 AM
killaford's Avatar
killaford
30-32 Max!
Old Nov 11, 2007 | 05:53 PM
dogman's Avatar
dogman
Originally Posted by killaford
30-32 Max!
Thanks......
Old Nov 11, 2007 | 08:16 PM
zss42002's Avatar
zss42002
what is max boost on a new 2007 6.0. 20-25??
Old Nov 11, 2007 | 08:21 PM
UGA33's Avatar
UGA33
should be able to hit 29 max. Thats what i hit in my 06
Old Nov 11, 2007 | 08:26 PM
zss42002's Avatar
zss42002
you hit 29 as soon as you floor it or does it peak at 20-25 then creap up to 29??
Old Nov 11, 2007 | 08:27 PM
denman81's Avatar
denman81
hey dogman, your not running a tuner are ya? if not id get the turbo checked, sounds like the vanes are sticking and giving you overboost. shouldn't beat over 30-32. Stock hg don't like it.
Old Nov 11, 2007 | 08:31 PM
UGA33's Avatar
UGA33
Off the line it will go straight to 25 then a split second shoot to 29
Old Nov 11, 2007 | 09:04 PM
tex25025's Avatar
tex25025
Mine would shoot up to 20 and then if I give a little more throttle it will shoot up to 30-31 easy. A little too easy, but I do enjoy that power.
Old Nov 12, 2007 | 05:02 AM
zss42002's Avatar
zss42002
are these readings from the stock turbo guage or no? my stock one goes to 20 then creeps up
Old Nov 12, 2007 | 05:12 AM
killaford's Avatar
killaford
thats normal for the lower gears with no load.
Old Nov 12, 2007 | 06:26 AM
tex25025's Avatar
tex25025
My readings are from both. They are normally within 1 to 2 psi of each other.
Old Nov 12, 2007 | 07:06 PM
UGA33's Avatar
UGA33
mine were from the stock guage
Old Nov 14, 2007 | 06:57 PM
dogman's Avatar
dogman
I'm going to pull it and clean it up. I was thinking the samething about the boost. The dealer is being a butthead about it so, I'll clean it. It was to be replaced but I dont think they did so if not I'll hand it over to some ford people I know.
WRABER
Apr 28, 2013 01:59 AM
desertrat64
Sep 29, 2010 01:11 PM
secondarychaos
Feb 25, 2008 06:22 PM
Firestarter116
Apr 28, 2007 01:28 PM
firemanbird
Aug 9, 2006 10:34 PM
