towing package
Old Apr 1, 2006 | 10:43 AM
luvemhot's Avatar
luvemhot
towing package
what all is with the towing package? i was told i had it but the wiring at the back for a trailer only has 4 pins? thanks Keith
Old Apr 1, 2006 | 11:14 AM
Kwikkordead's Avatar
Kwikkordead
I'm not real sure, but I think it's the trailer wiring sans the brake controller until you get up to the 2005 model year. Maybe a bigger transmission cooler as well for the gassers?
Old Apr 1, 2006 | 04:46 PM
CAT_man_963's Avatar
CAT_man_963
If I'm not mistaken the package is also a change in the rear springs....
My 2002 came with the 4-pin, and the 7-pin connectors stock - but I kinda think the early Superduties didn't have that.
Mine also had the wiring, and a pig-tail in the glove box, to hook up the brake controller under the dash - no wire splicing was needed.
Old Apr 2, 2006 | 12:47 AM
Lushman's Avatar
Lushman
My 2000 has the 4 pin in the rear as well. The kit that came with my truck as the towing package contained 2 relays and 2 30amp fuses that can be used to hook up either a 6 or 7 pin connector. All of my wiring is there just need to be hooked up. It also came with the connector to hook up under the dash for a brake controller.
