al. intake. 406?
Old Apr 2, 2006 | 01:37 PM
ebstard944's Avatar
ebstard944
OK, I found the date casting 6F28 and looked long and hard at the block # and think it is really C6ME-A. I cant tell about the mounting holes. Are they on the crossmembers? And the date casting was the smaller 1 below the oil fillter.
Thanks
Erin
Old Apr 2, 2006 | 02:21 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
I bet your right on the C6ME-A. The 6F28 is the date code of 66/June/28th. Also the block has the 4 bolt motor mounts. Most likely the 63 C3 intake was added at some point. The bad news that casting number is shared between 4 different bore blocks with a possible 7 plus combinations of CID. Most common bore blocks are the 352 at 4.00, the 360,390,410 at 4.05 and the 428 at 4.13. The crank stroke is easy enough to check. That can help nail it down leaving the cyl bore mystery until a head is removed. The 352 and 360 both share a 3.50" stroke. The 390 and 427 a 3.78" stroke. The 410 and 428 a 3.984" stroke. The 427 did not use a C6ME-A casting number so if you see a 3.78" stroke it's a 390 more than likely.
G.
Old Apr 4, 2006 | 08:16 AM
hiball3985's Avatar
hiball3985
I would say more than likely its a 390, don't think they used 352 in Mercs
Old Apr 4, 2006 | 02:43 PM
Bear 45/70's Avatar
Bear 45/70
Mercury used 352s in 1961 and 1962 in a 2 barrel version only.
Old Apr 4, 2006 | 02:47 PM
hiball3985's Avatar
hiball3985
yes thats right, but I thought we were talking about his 66 date code engine
7.3stroker2
Aug 21, 2022 12:55 AM
Ford4lif3
5.0L Coyote
Mar 17, 2019 09:17 AM
new7.3owner
Jun 24, 2014 06:34 PM
TLK380
Jul 21, 2010 05:49 PM
nathan5603
1983 - 2012 Ranger & B-Series
22
Dec 7, 2006 08:41 PM
