Coolant in intake. ..
Old Feb 4, 2016 | 04:49 PM
7.3stroker2's Avatar
7.3stroker2
I know the coolant in intake topic has been beat to a pulp. .. but with an egr delete, would a bad head gasket actually fill up the intake with the truck sitting for a few months? It hydrolocked and it got parked. Pulled the intake manifold off now and most of the intake holes into the head are clear full of coolant. Would it run back up into the intake or could i have another problem like a cracked intake manifold?
Old Feb 5, 2016 | 06:46 AM
Jmoen7's Avatar
Jmoen7
You are going to have alot more issues than that, with parking a hydrolocked motor for months. With an EGR delete, really the only way for coolant to get in there is a bad gasket or cracked head. Either way, you will have to tear it down the same to check. Replace the gasket, get head studs and have the heads checked
Old Feb 5, 2016 | 08:12 AM
7.3stroker2
I hear ya. It just seemed strange that it would fill up a bunch of intake holes from a bad gasket that is 6 inches lower. but i guess I'll tear it down and see.
Old Aug 16, 2022 | 11:00 PM
Fordfamily63's Avatar
Fordfamily63
2nd Gear
I know its old but can't seem to find anything. Shot in dark intake with water no egr cooler deleted correctly an studded 06 f250 did you ever find what did it same problem oil cooler pressure tested to be good . Oil in degas bottle and coolant in intake. Everything says egr but I don't have any of the egr system.
Old Aug 17, 2022 | 03:41 AM
Hartwig's Avatar
Hartwig
Coolant/water in intake ports = pull heads, + 90% disassemble engine.
If oil cooler pressure test passed (how did you done it?), check front cover / front cover gasket.
Old Aug 21, 2022 | 12:55 AM
Fordfamily63
2nd Gear
Had plugs in oil side of cooler one had air chuck soap an water on coolant side no bubbles an 50 psi didn't lose pressure either. My first diesel engine I've been in to. The only one that has coolant in valve side is 2nd cylinder driver side. The o rings look junk . The fact it has no coolant in oil just oil in coolant has me messed up. I understand the hg problems but do not understand how coolant is in intake with j tube for egr . I do plan on redoing coolant filter an freeze plug the pump and rerouting coolant line .
7.3stroker2
Feb 4, 2016 04:28 PM
99red150
Modular V8 (4.6L, 5.4L)
Oct 18, 2007 07:12 AM
BLK94F150
Oct 1, 2006 11:45 AM
RichardMaerz69
Feb 18, 2004 03:07 PM
Clint380
1983 - 2012 Ranger & B-Series
Nov 12, 2003 06:06 AM
