EBV sensor
Old Mar 30, 2006 | 09:22 AM
emxmagnum's Avatar
emxmagnum
EBV sensor
Does anybody know where the EBV sensor is on an 02 PSD? I run a straight pipe and the thing sounds like a hurricane when the valve closes. Im assuming that if I disconnect the sensor, the valve will remain open (or closed I guess if i pull the plug when its closed).
Any advice?
Old Mar 30, 2006 | 11:10 AM
tjbeggs's Avatar
tjbeggs
a better way is to disconnect the ebpv solenoid on the turbo pedestal. on located on the pedestal below the turbo on the front side down low in the middle. it the only connector attached there. just unplug that and you will be set.
andy's2000
26
Nov 6, 2016 08:42 PM
MRStace84
Sep 2, 2016 11:34 AM
bubba_3711
Dec 2, 2015 09:13 PM
brjarrell
Nov 23, 2014 02:16 PM
PowerStroke_KiD
Mar 15, 2011 08:28 AM
