Rear liftgate and glass latch cables -1998 Expedition
Old Jun 1, 2012 | 08:58 PM
Gevans17's Avatar
Gevans17
Anyone know where to order the 2 cables for the rear hatch glass and liftgate latch? Online Ford parts dealers show a "cable" for $50, but you cannot tell if it is BOTH cables or just 1 as parts diagram is crappy.
Also cannot tell if it is the cable for the glass or the liftgate. I read posts here where cables were had for approx $25 each. Called a local Ford dealer, but parts guy insisted i needed to replace the entire lock mechanism just to get the cable(s), which i do not think is correct. Any help appreciated. Thanks in advance.
Old Jun 29, 2012 | 10:22 AM
WiNgRg's Avatar
WiNgRg
want to know if you get those cables part number i have same problem.
Old Jun 30, 2012 | 06:10 AM
johnpvb's Avatar
johnpvb
It is called a "Rod Assembly" and you do need two, one for each latch. P/N F2UZ*15264A65*B
Cost $51.07 ea plus tax in 2010 when I had to replace mine after they broke. Replacing the window latch rod took a little ingenuity since it would appear to be built around into the latch, but a little careful bending of the metal plate let me slip it out and then slip in the new one, bending it back in place like new again.
Good luck! (sorry I didn't take pics to help more.)
Old Jul 1, 2012 | 09:16 AM
Gevans17's Avatar
Gevans17
liftgate cables
So Ford calls it a "rod" even though its a cable? And both the glass and liftgate latch "rods" are the same part number? Thanks for your help
Old Jul 1, 2012 | 09:00 PM
johnpvb's Avatar
johnpvb
Yes, it's called a rod, and yes, same part number. Good luck!
Old Jul 1, 2012 | 09:09 PM
Gevans17's Avatar
Gevans17
liftgate cAbles
THANK YOU Johnpvb! I have been searching for the part numbers for 2 weeks. Ford parts dealers have been pretty clueless about it as well. Thanks again for your help.
Old Aug 13, 2024 | 03:17 PM
Gaigler's Avatar
Gaigler
2nd Gear
Cable set of two
Walmart.com sells a set of two cables for 14.30 received mine yesterday. Fit perfect. F2UZ15264A65B is the part number. Free shipping also.
crankytroll
Paint & Bodywork
Aug 13, 2024 03:21 PM
Kevin 1988
25
Sep 6, 2017 12:39 PM
kevinparks1k
2004 - 2008 F150
Dec 30, 2011 06:30 PM
KIDkiser
Jun 26, 2011 08:22 PM
kerim1
Aug 29, 2010 09:22 PM
