In Need To Know What Kind Of Throttle Cable That Is Easy To Install For Holley 390 Offy Setupim Planning On Ordering It From Jegs And I Wont To Get It All At Once And Do It Rightand If Anyone Can Post Pics Of Your Setup For Ideals On Brackets.thanks,and If There Is Anything Eles I Should Order Beside Carb,intake,and Cable Let Me Know.
I've got pics of a bracket I made in my gallery so that you can continue to use the Ford 1bbl. throttle cable on your Holley 390.
The bracket may not be easier (I have no experience with aftermarket throttle cables), But it is definetly cheaper. If you have a welder and some mechanical ability, which I assume you do if you are attemting to install a 4bbl. on an I-6, I say try and make the bracket. The bracket was much easier to make than I thought.
thanks for the help but ireally wnted to use a new cable my old one is a little thrashed i heard of okar cables being really good but what length cable do i need
