Anyone tried hooking Lokar Throttle Cable to stock gas pedal? - 1979 F100
Hey guys,
I have reached the step of my engine and tranny swap of installing a new summit carb and intake to my 351w and AOD Transmission. As many of you know, hooking an AOD transmission to an aftermarket carb requires a Lokar TV cable, Lokar carb bracket, and Lokar throttle cable. Everything is a go, except the throttle cable. It's designed to run through the firewall to a Lokar gas pedal.... but i dont have the money to buy a $150 gas pedal. My truck has the throttle arm that comes up right behind the intake manifold. Has anyone made the stock gas pedal work with a Lokar throttle cable? What kind of mods am I looking at, if any? Thanks for any suggestions!
1979 F100 Custom - 351w - AOD
Check out this thread: https://www.ford-trucks.com/forums/1...tle-cable.html
this link: Lokar throttle cable on stock pedal ? - Ford Mustang Forums : Corral.net Mustang Forum
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
That does help. Thank you. maybe i can come up with something.
MCD46
03-02-2015 12:05 PM
Sport45
04-30-2007 02:44 PM
hippyman01
04-03-2006 09:42 PM
