Idler pulley problem
Old Mar 27, 2006 | 08:56 PM
1969fordguy's Avatar
1969fordguy
Thanks. I'll print the NAPA screen shot out so that my next visit to the store will settle this!
Oh yeah, FTE gets it done!
Old Mar 27, 2006 | 09:01 PM
1997F-350's Avatar
1997F-350
might as well buy 4 of them. replace all 3 and keep a spare in the glove box.
Old Mar 29, 2006 | 09:47 AM
1969fordguy
Alright guys, this is kicking my butt... The tensioner is not aligned just right with all of the other pulleys. It is turned to the side a little. When it is pulled back just a bit then it lines up just right. Is there an adjustment on the tensioner? I priced a new one from NAPA - $95.00 ouch. On the brighter side I did get new bearings for $3 each.
Old Mar 29, 2006 | 11:12 AM
1997F-350's Avatar
1997F-350
how does it look once you start it up and its running? if you replaced the belt its gonna squeak.
good score on the bearings thats cheap.
Old Mar 29, 2006 | 01:34 PM
1969fordguy
It looks like it is turned sideways (the tensioner pulley) maybe 10 degrees. With the engine running, the belt does not squeak or chirp. It just doesn't look right. What made me think it could be adjusted is when you pull the tensioner back some (with a 15mm breaker bar) it lines up correctly. Or, as the tensioner goes through it's travel it gets out of alignment.
Old Mar 29, 2006 | 10:50 PM
Kwikkordead's Avatar
Kwikkordead
Replace that thing before it takes something else out. It HAS to be in perfect alignment or it will overheat the belt and destroy it.
Old Mar 30, 2006 | 07:12 AM
1969fordguy
Yes sir, a new idler will be purchased.
Old Mar 31, 2006 | 09:01 AM
1969fordguy
New tensioner from AutoZone installed, $46
New bearings from NAPA installed, $3 each
Finding out how to do it all myself from FTE members, PRICELESS
bduemig
Jun 26, 2012 08:26 AM
powerstroker100
Aug 25, 2010 04:43 AM
87_gt
Apr 9, 2009 09:49 AM
2000f150toms
1997 - 2003 F150
Jun 11, 2007 07:32 PM
