question on guages
Old Mar 24, 2006 | 06:39 PM
crawlinrs's Avatar
crawlinrs
question on guages
I've got 2 gauges. Trans temp and egt. THe egt was installed by PO, but i'm not sure its in the right location. my friend has an 05 with the banks 6 gun kit. His reads higher than mine at all times. I think His sensor is in the manifold. Just wondering if this is where i should put the egt sensor on my truck? 92 F350 7.3 non-turbo
Also, the trans temp sensor, no nistructions with it. Just the guage and sensor, Where should this sensor be placed? Inline or in te pan? Thanks for the help.
Old Mar 24, 2006 | 08:47 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Where is your pyro mounted now if not in the manifold?
Old Mar 24, 2006 | 08:52 PM
crawlinrs's Avatar
crawlinrs
i think its down in the y-pipe. its been cold lately and the truck won't fit in the garage. I just want to make sure it's supposed to go in the maniflod like i thought.
Old Mar 25, 2006 | 04:45 AM
tjc transport's Avatar
tjc transport
i ain't rite
it don't have to go in the manifold, the banks turbo kit mounts the pyrometer probe in the turbo housing to get a combined reading fron both pipes. as long as you keep your egt's under 1100º, you will be fine.
as for the trans temp sender, it should be mounted in the pan.
Old Mar 25, 2006 | 07:58 AM
crawlinrs's Avatar
crawlinrs
NBT22555
Jun 13, 2014 06:51 PM
greenstar
Mar 5, 2014 06:24 AM
dieselsmoker
6.4L Power Stroke Diesel
Apr 16, 2010 09:19 AM
strokin'_tatsch
Nov 5, 2009 07:16 AM
southbound35west
Mar 15, 2007 01:02 PM
