gauge sensor placement
Old Jun 12, 2014 | 08:57 PM
NBT22555's Avatar
NBT22555
I just picked up a 3 pod pillar gauge with egt trans temp and boost. Directions arent really that clear on egt sensor placement so I am looking for feed back on that first and the trans temp sensor/test port location on my 99 f350 7.3l.
thank you in advance
Old Jun 12, 2014 | 09:06 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
EGT sensor usually goes in driver side manifold pretty much where it is easy to get at with a drill from below. Trans sensor should go in the bung on the driver side, above the pan in a bung on the side. Check out the many install instructions on RiffRaff.
Old Jun 13, 2014 | 08:14 AM
Tugly's Avatar
Tugly
You'll see mine behind the orange block heater cord.
Old Jun 13, 2014 | 06:08 PM
NBT22555's Avatar
NBT22555
Thank you gonna get it done tomorrow
Old Jun 13, 2014 | 06:51 PM
HKusp's Avatar
HKusp
My preference is similar to Tugly's but lower down on the bottom of the drivers side manifold. It helps when you are drilling for the filings to fall to a low point.
Dadocho
Jun 20, 2016 04:35 PM
noober0x
Dec 11, 2015 02:50 PM
wastingas
All Things Towing
Jan 15, 2014 11:27 PM
dbunce86
Jun 30, 2013 04:36 PM
jonesy23
Sep 7, 2006 08:21 PM
