Ignition Switch
Old Mar 22, 2006 | 11:16 AM
SpankF100's Avatar
SpankF100
Question Ignition Switch
Does anyone know how to swap out the ignition switch? I recently bought a door lock, ingition combo and I have no idea how to pull out the old ignition. I tried putting a pin in the hole and turning the key as I had read on this site but that failed. So, if anyone has advice please post.
Old Mar 22, 2006 | 11:39 AM
1972FordCustom's Avatar
1972FordCustom
if I remember correctly, it's been awhile since I replaced mine, you have to put a paper clip or something similair that will fit in the hole while its in the off position, push it in all the way and turn it to acc. it might turn a little past b4 it comes out, but it should come out
Old Mar 22, 2006 | 12:11 PM
bertha66's Avatar
bertha66
Turn your switch to Acc. and then push a paper chip into the hole a push the button and the key should turn more and pull out.
rhoward
Apr 22, 2026 11:16 AM
yankeerebel
17
Oct 22, 2013 05:51 PM
geoaigel
Dec 1, 2009 09:55 PM
Bertelrud
Nov 21, 2008 05:38 PM
400-CI
Electrical Systems/Wiring
Sep 26, 2008 05:52 PM
