Always disconnect the battery first. If you insert the key and move to accesory there should be a release pin on the face to remove it.
Turn the key counterclockwise and pull the key and lock assembly out of the switch. The removal of the rest is start taking this apart till it comes out
Could anyone tell me what this is used for? It is labeled P2, But as you can see, There is a connector on the Ignition Switch, But there is no slot for it to go into.
I think you have the wrong Ignition switch as P2 was used on newer Diesels.
How ever you should have a P and this would be the Proof (or PROVE OUT) terminal for the dash lights.
