help with solid front axle swap
Old Mar 22, 2006 | 09:09 AM
mustanginca's Avatar
mustanginca
I just bought a 93 f250 with the 460 and was told I should switch to a solid front axle I noticed the f350's came with one. I already have a six inch lift with 37" tires but one stiff ride. Is there any kits out there and could I just use a f350 as a bolt on? Does this open me up for more suspension options?
Old Mar 22, 2006 | 10:53 AM
s8whiskey's Avatar
s8whiskey
If you get a F350 donor truck you can do a complete swap just takes the time to do it and the tools and when you get that axle you are limited only by the strength of the axles in proportion to tire sizes. AKA go as big as you want till things break. Usally around 38-40ish is the limit.
TexasDiesel97
Dec 21, 2012 10:11 AM
Njdub
Offroad & 4x4
Dec 15, 2010 12:56 AM
weldboy
May 4, 2006 12:01 PM
dada
Aug 9, 2002 05:15 PM
4xfordman
Feb 9, 2002 11:24 PM
