My wipers don't work, any ideal's on what to do. I checked fuse's, & relays. switch was in parameters for fast, slow & off but didn't change on the delay. I ran a hot wire to motor & it runs. ( ANY HELP APPRECIATED)
The switch part is made real cheap. Pull the end off of the stick, pop off cover and remove the screw, and inspect the switch. You can try the jumper there. Be careful and don't bend any of the contacts until you decide which one is off if it is the problem.
depending on the year of the Superduty...I believe the wiper-motor switch is under a recall for freezing up and starting fires? If so...the dealership should foot the bill for the repairs...
I went to the ford fleet site and tried to look at the recalls and i had to have some kind of fomoco dealer id...so i put in my vin number somewhere else and it still didn't work...as in said nothing for my 99
Medic66,there is a tsb or recal for the cruise control switches that cause fires but not the wiper multifunction sw.but the wires may be in the same area.
Did you get a recall notice on this?
Rich
Rich
No I didn't....not sure why I wouldn't qualify though.
Recall 05V388000: Cruise Control Switch Replacement
MAKE/MODELS: MODEL/BUILD YEARS:
Ford/Bronco 1994-1996
Ford/Expedition 1997-2002
Ford/F150 1994-2002
Ford/F250 1994-1999
Lincoln/Blackwood 2002
Lincoln/Navigator 1998-2002
MANUFACTURER: Ford Motor Company
NHTSA CAMPAIGN ID NUMBER: 05V388000 MFG'S REPORT DATE: September 07, 2005
COMPONENT: Vehicle Speed Control
POTENTIAL NUMBER OF UNITS AFFECTED: 3800000
SUMMARY:
On certain pickup trucks and sport utility vehicles equipped with speed control, the speed control deactivation switch may overheat, smoke, or burn.
CONSEQUENCE:
A fire at the switch could occur.
REMEDY:
As an interim repair, owners will be instructed to return their vehicles to their dealers to have the speed control deactivation switch disconnected. As soon as replacement parts are available (expected mid-October 2005), owners will be instructed to return to the dealers for installation of a fused wiring harness. The interim owner notification is expected to begin during the week of September 12, 2005. Owners should contact Ford AT 1-800-392-3673.
NOTES:
Ford recall No. 05S28. Customers can also contact The National Highway Traffic Safety Administration's Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to http://www.safercar.gov.
