Will Ford Oem Bug Shield Damage Paint
Old Mar 21, 2006 | 10:34 PM
JOHN KENNEDY's Avatar
JOHN KENNEDY
Lightbulb Will Ford Oem Bug Shield Damage Paint
I Recently Installed The New Bug Shield From Ford On My 06 Screw.does Anyone Have Any Experience With (paint) Damage From The Slip- On Clamps Or Where The Shield Clamps Between The Grill/hood
Old Mar 22, 2006 | 05:55 AM
TexasGuy001's Avatar
TexasGuy001
I have never had a problem with a bug guard before. I have always had one and have had one on all of my trucks. I will say this. About twice a year take it off and clean/wax behind it. Make sure the rubber stops are in the correct placing, if it has any. If it didn't come with any, you may want to see if you think it needs them. If it does, they have little clear rubber bumpers at Wally World.
Old Mar 22, 2006 | 06:30 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 22, 2006 | 09:48 AM
is300wrx's Avatar
is300wrx
without the rubber thingys, and you clamp on that metal bracket, you will chip your pait. its metal on paint contact! I lost my rubber padding so I just taped the edge of my hood with two layers of double sided tape (thick padding). It works.
Old Mar 23, 2006 | 07:24 PM
Ferguson65's Avatar
Ferguson65
I bought the ford one and brougt it home to put on, saw those clips, and took it back to the dealer for a refund. I bought a lund one at cabela's, it has small clear vynil pieces that go on the hood, under the clips, and the clips are rubber coated. It doesn't look as clean as the ford one, but paint protection is number one with this one. The wind whistle is annoying.
spiggy769's Avatar
spiggy769
The Factory Bug Deflector comes with 2 3M Self Adhesive pads in which the mounting clips rest on. Other then the possible scratch undreneath the hood...I cannot see how it will in anyway damage the paint if properly installed per manufacturer's Instructs.
Old Mar 23, 2006 | 10:32 PM
is300wrx's Avatar
is300wrx
Very true. Not likely to scratch...otherwise, my OCD and **** self will not allow this to be installed if I saw any scratches from it. This is coming from a guy that had his right fender painted because there was a small 1" scratch from my zipper ($350 later)
Mustangking1
Oct 1, 2013 10:56 AM
Ralph
2009 - 2014 F150
Mar 9, 2012 08:48 AM
moosesp
2009 - 2014 F150
Apr 25, 2010 03:52 PM
bassaway
2004 - 2008 F150
18
Jan 27, 2008 04:44 PM
WV Hound Dog
Appearance & Dress-Up
Feb 2, 2004 11:57 PM
