Wind Whistle with bug shield.
Old Feb 15, 2009 | 12:25 AM
moosesp's Avatar
moosesp
Has anyone experienced a wind whistle from what sounds like the drives side front after the bug shield has been installed?
Old Feb 15, 2009 | 08:10 AM
09 platinum's Avatar
09 platinum
do not hear a whistle on my platinum
Old Feb 15, 2009 | 08:13 AM
moosesp's Avatar
moosesp
Do you have the full Smoked plastic one or the shorty chrome one? I have the full one!
Old Feb 15, 2009 | 03:15 PM
09 platinum
full factory smoked, although i should add on my 05 screw the bug sheild caused the hood to vibrate so bad the dealer took it off!!
Old Feb 15, 2009 | 07:56 PM
moosesp's Avatar
moosesp
I took the shield off today and the whistle is gone! I will contact the dealer this week and see what they say. Hope they are good about it.
Old Feb 8, 2010 | 09:05 PM
Joeymt3's Avatar
Joeymt3
Hey, I just installed a Bug Deflector II on my 2010 and now I have a annoying whistle at 70-80 mph. I removed it and the noise is gone. I will attempt to return it tomorrow and get a different one.
Old Feb 8, 2010 | 10:44 PM
Zmann's Avatar
Zmann
I had an issue with a 05 chevy .. I called the mfg and they stated the oem changed the window gasket and it actually created the issue ,, so I had to run a bead of clear silicone around the loose flap on the gasket .. problem solved ,, but a little bit lame IMHO ps I tested it with scotch tape before I commited
Old Feb 9, 2010 | 12:55 PM
berry1234's Avatar
berry1234
Tape the window seams with blue painters tape and see if it goes away.
Old Feb 9, 2010 | 04:15 PM
Joeymt3's Avatar
Joeymt3
I will check that out and post the results, thanks
Old Feb 9, 2010 | 08:29 PM
montecarlo31's Avatar
montecarlo31
X2 on my GM truck I got a roll of 3M double sided trim tape. I installed this and the wind noise went away. I'd try some blue painters tape and see if that helps with the noise. I would apply around the entire windshield and go from there.
Also, the platinum has a different windshield then the regular F-150, that may cause some differences in noise. His truck may make that noise but he may not hear it due to the added insulation.
Old Apr 25, 2010 | 03:50 PM
Joeymt3's Avatar
Joeymt3
I taped around the entire windsheild and drove it.......still whistled
I left the windsheild tape and added tape around the whole hood......still whistled
I left all that tape and then taped under the bug deflector, I filled the gap between the grille and deflector.....almost completely gone, just a slight whistle
Old Apr 25, 2010 | 03:52 PM
Joeymt3's Avatar
Joeymt3
Also, my friend has the same truck except his doesn't have the chrome package so his grill is different. He also has the same deflector as I do and his has the same whistle. so, the grille doesn't make a difference.
RJF1953
2015 - 2020 F150
Apr 6, 2017 05:18 PM
RJF1953
Aftermarket Products
May 16, 2016 08:07 AM
akappler
2009 - 2014 F150
29
Sep 4, 2014 03:52 AM
LovinLifeAtHome
Mar 29, 2006 01:12 AM
jcb67
Jun 9, 2002 06:30 AM
