The outer skin is the one on the outside, with paint, the inner surface of that would be inside the door. Inner door skin is the metal part of the door that is inside the vehicle; what your plastic door panel attaches to.
Two different types of underpad; open celled on the roof and back panel. Closed cell polyethylene in the doors and on the floor, also second layer on the roof and back panel. Have to use closed cell where there is a possibility of getting wet.
I wish I would have had an SPL meter to test inside before and after, as well as outside w/music playing inside.
I too ended up using carpeting underlayment. I bought some of the 1/2 inch rubber stuff that carpet installers use under premium carpet. It's rubber, and not the pressed foam stuff. 20 bucks for that, and then 2 cans of the 3m spray adhesive, and it sounds a lot better. Did the doors, under the mat, and the back firewall of the cab. Sounds good, for an XL stripped down package.
I thought I would add my $.02 I used a water blocking membrane on my Excursion called Fort-0-flash 40 that I got from a stucco company for free. It's a peel and stick and works great. it took about 5 rolls and cut the road noise by a lot. I also foam filled all my pillars and supports front to back.
Interesting, sounds like a good idea. Do you have an SPL meter to measure before and after dB readings? I am sure it is going to reduce some noise if you putting that much on, make sure you still have clearances for the windows.
Got my tax return today and bought a new toy... An SPL meter. At 70 MPH it ranged from 65 - 72 dB, and mostly reading 68 - 69 - "A" weighted and slow sampling. According to this site, the 2007 Mercedes S class averages from 66 - 68 dB.
wish I would have got a 'before' reading though.
That is pretty sweet, cant wait to get started on mine, I will have to do some pre reads prior to insulating, course getting to that range with a diesel may be a little more challenging.
I've been reading up a bit more on the subject and apparently there is, on some vehicles, a laminate glass package that can reduce interior noise by up to 6dB. That is interesting as most of the noise I noticed in the testing was wind noise coming through the glass.
There's also some products that are intended for the interior side of the hood. I don't have any experience with those, but from what I've been reading, they work well.
The europeans are quite a bit more advanced when it comes to noise reduction than NA; coming up with engine shrouds and such to get the vibration at the source instead of allowing it to propagate and have to deal with a larger problem.
I hear ya there for sure, I think the mini van is louder than my truck going down highway. There are some sound baffles for excursions that go under the dash, but I think I am going to go farther than that. Try for more treatment under the hood first as to eliminate the source, at least closer to the source. I have done a few mods that have definately quited the idle down. I currently have 50 sqft of fat mat in the garage, probably going to either use the same stuff as you did in addition to the fat mat or order another 100 sqft. Haven't really decided. I am going to concentrate the majority of it up front in and around engine compartment.
You'll need more than 36 feet for an effective install. Secondly, I lined my entire convertible with the stuff - works great. But I lined my truck with Damplifier, and it works the same - but like half the cost.
