Kickdown Lever Bushing Replacement?
Old Mar 20, 2006 | 06:17 PM
tractoman's Avatar
tractoman
In the process of rebuilding the carb and while disconnecting the kickdown lever I noticed a worn and broken plastic or nylon bushing where the kickdown lever attaches to the pin on the carb linkage. It is the bushing inside the hole at the top end of the kickdown lever. Is this replaceable? I can't seem to find this part.
Thanks for any help.
Old Mar 20, 2006 | 06:50 PM
LxMan1's Avatar
LxMan1
You might look thru a help catalog at your local parts store. I think I have seen them before.
Old Mar 21, 2006 | 01:06 AM
Polkat's Avatar
Polkat
I just bought one of them at Ford. Can't remember the part number, but if you have a Ford dealer locally with the part catalogs on microfilm, they can call up an image of your linkage and you can point it out to them.
Old Mar 22, 2006 | 05:24 PM
tractoman's Avatar
tractoman
I have been to two dealers and they can't find it. Anybody have a part number for this?
Thanks
Old Mar 22, 2006 | 05:32 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
what are you working on, the basic numbers the dealers need to look for are 7341, 7F330, 7F332,7A187 IT ALL DEPENDS ON THE TRUCK INFO!
Ed
Old Mar 22, 2006 | 05:57 PM
tractoman's Avatar
tractoman
I am working on a '76 F250 460 C6. Where the kickdown rod connects to the carb linkage, on the flat part of the kickdown rod is a plastic bushing that slides over the pin on the linkage, and then the circlip holds the end of the rod on the pin.
If you can help I will be very happy.
Thanks
Old Mar 22, 2006 | 09:28 PM
Mil1ion's Avatar
Mil1ion
Try the H.E.L.P. section at a parts store.
Old Mar 22, 2006 | 09:39 PM
tractoman's Avatar
tractoman
I should have mentioned, I have tried the HELP section (Dorman Products) at 3 stores and had 1 of them look in the master catalog. I cannot find it. Am I the only one with a worn out bushing?
Old Mar 23, 2006 | 10:51 AM
1978Crew's Avatar
1978Crew
no bushing at all
no, you are not the only one. I have no bushing at all.
Old Mar 23, 2006 | 11:23 AM
Parts Guy Wyatt
Former Vendor
The bushing for your truck was only serviced in the kickdown rod.
Part number D5TZ-7A187-A which is obsolete. I ran a locator and there is no one out there that has it. I looked in LMC truck catalog and they do not show it.
So you may wish to try some of these part numbers and join the mickey mouse club.
D5AZ-7341-C 3/8 id x 1/2 long x 15/32 od x 11/16
D5AZ-7341-A 7/32 id x 21/32 od
this is the most popular bushing used in many cars and trucks for the kick down bushing but I do not have the size.
EOAZ-7F330-A
go to local dealer and ask to look at these part numbers and maybe you can make one work.
Thanks Ed
Old Mar 23, 2006 | 12:14 PM
Mil1ion's Avatar
Mil1ion
I think it is shown here.
redbayredneck
Sep 8, 2016 11:06 AM
davidrozeboom1
Aug 26, 2016 12:34 PM
TheWedge1
Nov 20, 2009 10:52 PM
68F250CJ
20
Apr 25, 2007 11:18 AM
79Supercab
Nov 21, 2001 11:16 AM
