Jag IFS wheel bolt pattern?
Old Mar 20, 2006 | 09:50 AM
badtomatoes's Avatar
badtomatoes
Can anyone tell me what the wheel bolt pattern is on the Jag IFS clip?
Thanks!
Old Mar 20, 2006 | 03:13 PM
hotrod48's Avatar
hotrod48
For some reason I'm thinking it's the small Chevy pattern (5x4.75). I can't remember for sure. It should be listed in this thread: https://www.ford-trucks.com/forums/s...ght=jaguar+ifs Lots of good reading there anyway. Hope this helps.
hotrod48
Old Mar 20, 2006 | 04:18 PM
mkabwe's Avatar
mkabwe
Its the same bolt pattern as a chevy 5x4.75
Old Mar 20, 2006 | 09:46 PM
rhopper's Avatar
rhopper
I checked this recently as I'm going to use a Jag myself, as soon as I find one. The bolt pattern is 5x120mm, which works out to 5x4.72. Close enough. I did read that the hub, and wheel pilot hole, are larger than stock chevy. Most custom wheels, however, have a large pilot hole to make fitment universal. You could buy/make hubcentric rings to take up the gap. Or say the heck with it, it's a truck.
Old Mar 21, 2006 | 07:35 AM
badtomatoes
Thanks for all the info!
After doing some googling, I found that the Jaguar hub is set up for using hubcentric wheels, meaning that the center hole of the wheel keeps the wheel in the exact location needed on the hub. Most wheels I'm used to are lug-centric. Does anyone make adapters or spacer rings to go from a hub centric hub to lug centric wheel? All I can find is the other way around.
I know this is a small detail, but sometimes it's the details that'll kill you. Maybe I'm just better off sticking with the 5.5" bolt pattern and a straight axle...
Old Mar 21, 2006 | 02:00 PM
Lwlandy's Avatar
Lwlandy
Hi Bad Tomatoes,
I am using a Jag rear end on my 56 effie. When I got my truck it had wheel adaptors and had Chevy Ralliegh wheels fitted to a standard 9". I am still using the chevy wheels to roll the chassis around on the Jag rear end, but can definately confirm that the center hubs on the Jag are slightly larger. The Rallieghs wont actually fit flush to the hub.
I cant say for sure, as I am not in the wheel business, but from what I have seen of the different types, it comes down to the Lug nuts used. Hub centered tend to use flat faced nuts/bolts and use the hub to locate, where as nut centered have a chamfered face to the holes. I think most aftermarket wheels tend to use the chamfered nuts.
Depending on what wheels you want, I would suggest you check that the center hole is large enough to clear the hub, as stated earlier, some aftermarket wheels tend to be anyway and use the chamfered nuts but I would always check before partuing with any of your hard earned.
Hope this helps.
Lee
Old Mar 22, 2006 | 11:47 AM
rhopper's Avatar
rhopper
Just checked an American Racing spec sheet, typical center bore on a 5/4.75 aluminum wheel is 3.27 inches, with a small chamfer. What is the diameter of the hub?
Old Mar 24, 2006 | 11:29 PM
halfdone's Avatar
halfdone
Lee is correct, you can use lug centred Chevy pattern wheels on Jag's as long as you use the correct nuts....namely any old ford ones.
Vintique early ford style wheels have both patterns.....so once the cap is on, no one will know you have a chevy bolt pattern
Jag is Chevy pattern with Ford style studs........bloody poms
Rollingmenace
May 6, 2015 11:11 PM
iwanaflattie
Mar 6, 2012 04:44 PM
rpol7966
18
Aug 4, 2010 04:51 PM
truckfarmer
Nov 27, 2006 03:46 PM
rhopper
17
Mar 26, 2006 04:14 AM
