My way of wiring makes the spark weak but it still fires the plugs. I think the spark works well but I need to put on a manual choke to make the flames bigger and hotter!
In this area there is a club called "Keepers of the Flame", to be in this club you must have FLAME THROWERS. These people always have a crowd around them at shows. The exhaust flames look so awsome Ihave been thinking about trying to use small injectors to do this on a cat equiped truck.
Project Supercab: in the diagram you posted, what triggers the coil?
The relay buzzes when wired this way. The buzzing cycles the coil and makes endless blue sparks
carefull this basic design will make a stun gun and does hurt if the coil discharges into you. trust me here it's like 30000 volts and it can jump a gap over an inch or more.
The vibrating relay will eat its self up in short time, better to have a transistor controlled unit or one with a 555 timer like the one 1Short posted back in 3-7-02. 1Short's design fires a Motorcraft electronic ignition module, a cheap Pick-N-Pull item. Get a green box from a 74-76 Ford truck pt# FF401 for the hottest spark or Kragen for a Niehoff unit $45.99, add 2 resistors, 1 555 timer, capacitor and a coil for one pipe or two sets for your dual exhaust.
keg...(noun)...crunchy on the outside, yummy on the inside.
.....=o&o>.....
I wired up a simple system last night and made it work. Pretty neat stuff. I wired the extra coil in parallel with the factory coil, drilled a hole in the tailpipe and placed a plug in it. It wouldn't light, despite a good spark. So I had to do a manual choke with my hand (the car is a 1985 mustang GT with an automatic choke) while reving the engine, it lit up quite nicely!
I don't think I will have the flamethrower installed on this car, the back bumper is plastic!!!!
A old Harley coil works for a simple installation, single primary with dual secondary for them twice piped exhausts. Propane with nitrous injectors to prevent engine wear.
.....=o&o>.....
