blowin' fuses!!!
Old Mar 19, 2006 | 11:41 AM
14psd's Avatar
14psd
Cool blowin' fuses!!!
Please help! My '95 psd is blowin' fuses left and right! The fuse for the gpr keeps blowing. I have changed the gpr and I'm STILL blowin' fuses. Of course without that fuse my baby doesn't want to start in the cold, let alone at all.
Old Mar 19, 2006 | 01:01 PM
14psd's Avatar
14psd
I guess I should have put my question in there. What or why do I keep blowin' fuses. The "wait to start" lite doesn't even come on.
Old Mar 19, 2006 | 01:16 PM
79f-250custom's Avatar
79f-250custom
bad glow plug regulator?
Mitch
Old Mar 19, 2006 | 01:19 PM
Briansshop's Avatar
Briansshop
If you're blowing # 22 I hear that it's prob the fuel heating element in the fuel bowl. Haven't had the prob myself, but seems pretty common.You can unhook it at the bowl and see if that does it.Good luck w/it.
Brian
Old Mar 19, 2006 | 01:22 PM
Jerme's Avatar
Jerme
No WTS sounds like your fuel heater is shorting out. There's a wire you can unplug to disable the heater on the drivers side of the fpr, i forget which one though, some people just unplug it anyways cuz they don't need it. Or you can take the filter out and look for the wire at the bottom if it's grounding itself out.
Old Mar 19, 2006 | 01:43 PM
14psd's Avatar
14psd
brian which wire is it the top one or the bottom one. One has a big plug the other is smaller (lower). checked gpr it good, put on buddy's truck and worked. thx 79.
barebackjake's Avatar
barebackjake
check fuse #22 possible fuel heater shorted out. red wire going into lower part of bowl.
check the wiring from the gpr to under the vc's where the gp's are. sounds like a shorted out wire.
Old Mar 19, 2006 | 01:57 PM
14psd's Avatar
14psd
Talking
Its the upper one with the bigger plug on it. THANK YOU GUYS THANK YOU THANK YOU. You just made my day. I just found my new hang out spot! I have done a lot of the work on my truck myself but had not encountered this problem. THANKS AGAIN !!!!!!!!!!!!!!!
Old Mar 19, 2006 | 02:13 PM
barebackjake
your welcome...dang its been a long day, lower wire....lol
Old Mar 19, 2006 | 02:41 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE 14psd.
You live in Troy eh? Small world. My sis-in-law works/lives there.
Old Mar 20, 2006 | 01:36 AM
rockyrider's Avatar
rockyrider
I'm just down the road from ya in New Melle.
Yeah, this is a good place to visit everyday.
twarrior
Oct 12, 2012 04:37 PM
bballcrf
Oct 3, 2006 01:48 PM
REDONE97
Electrical Systems/Wiring
Oct 30, 2005 09:55 PM
Six Niner
Jul 26, 2004 05:04 PM
Bronko 86
1978 - 1996 Big Bronco
Jan 30, 2003 02:32 PM
