keep blowin fuses
Old Aug 27, 2006 | 10:57 PM
bballcrf's Avatar
bballcrf
keep blowin fuses
hey guys my cig. lighter fuse keeps blowin the proper number fuse. i dont use the lighter itself but do use it for accesories.i recently replaced it,used my cell phone charger,worked fine,next day it didnt work,and the fuse was blown.where do i start?
Old Aug 28, 2006 | 05:47 AM
Cuda_jim's Avatar
Cuda_jim
Do you have some after market items installed in you truck? Maybe someone tagged that point for power.
BTW: The 15 amp fuse (#16) also protects the DLC (Data link connector).
Old Aug 30, 2006 | 09:30 PM
bballcrf's Avatar
bballcrf
sorry for the delay been workin on the dirtbikes,the fuse spot has no after market items and its still blowin fuses,is this bad for the dlc?this may be irrelevant but my fuel heater solder joints are broke under the fuel filter,would that have anything to do with it?
Old Aug 30, 2006 | 09:39 PM
1997F-350's Avatar
1997F-350
any money fall in the inside of cig lighter?
Old Aug 30, 2006 | 10:05 PM
bballcrf's Avatar
bballcrf
no,money in the hole,its clean ive checked it for shorting
Old Aug 30, 2006 | 11:42 PM
F350_Hauler's Avatar
F350_Hauler
You could unplug the cigarette lighter and replace the fuse and wait a day or so to see if it blows again.
Old Aug 30, 2006 | 11:46 PM
bballcrf's Avatar
bballcrf
ok ill give that a try
Old Aug 30, 2006 | 11:51 PM
F350_Hauler
Try to inspect that wire, too. I'm not sure how much of it you'll be able to see but it could be rubbed or pinched somewhere along the way so it's grounding to short. Check near the top of your brake and clutch pedals, too. If it works for a while and then doesn't later on, something is changing along the way like with movement or vibration.
Old Aug 31, 2006 | 10:39 PM
helifixer's Avatar
helifixer
hope you find it soon my '97 is doing the same thing.
Old Oct 3, 2006 | 01:48 PM
bballcrf's Avatar
bballcrf
update
think i found the prob. i used my cell charger in another truck, and that cig lighter fuse blew!!so i think i know what the prob. is.also figured out how upload pics in profile, check them out
Wild Ziggy
Nov 2, 2012 08:08 AM
twarrior
Oct 12, 2012 04:37 PM
14psd
Mar 20, 2006 01:36 AM
REDONE97
Electrical Systems/Wiring
Oct 30, 2005 09:55 PM
Bronko 86
1978 - 1996 Big Bronco
Jan 30, 2003 02:32 PM
