Pilot bearing removal
OK, I hope someone knows a trick or two...... I have been trying to replace the pilot bearing in my 65 F100 with the 300 engine and am having problems. On my 1st try of course just the center of the bearing came out. All other attempts to get the remaining piece out have been foiled by the bearing actually breaking in slivers and allowing the removal tool to pull free. I have been placing the hooked sections of the tool in the two inner groves on the back of the remaining piece but the bearing keeps chipping when I attempt removal. I'm afraid to apply any more force to spread the tool hooks fearing they might break. Any thoughts will be greatly appreciated!
Steve in Riverside
Steve in Riverside
Originally Posted by FordBoypete
Bearing or bushing, you can't thread anything into the center/inner race of a roller bearing pilot bearing, at least not like you can in a bronze bushing.
FBp
FBp
Allen
Wow, nothing like a challenge. The problem with pullers is that there has to be a trmendous amount of pressure applied in order to move something that has "glued" itself to the bore. For this reason I prefer to use a slide hammer when pulling pilots. I made one out of a long bolt and a heavy socket for the slide part. I have configured the bolt head with a grinder to fit into the bearing/bushing hole leaving enough shoulder on one side for a grip on the back of the bearing/bushing. I've had to dress the shoulder up a few times as the bolt is usually softer than the bearing/bushing but with enough smacks, I haven't found one that can't be removed in this manner. Steve
Flaflathead
04-04-2005 08:48 PM
88grandmarquis
08-06-2004 04:19 PM
1980F100
08-29-2002 02:16 PM
