Sponsored by: Real Truck
Problems with door locks
Old Mar 15, 2006 | 10:31 PM
ssssteak's Avatar
ssssteak
Cool Problems
2000 350 diesel- all auto door locks do not work- mechanic says all need to be replaced. This seems strange- Cruise control failed too. Rear axle seals failed and ruined brake pads-new shocks needed. Rear axle replace 3 times - vehicle has 62000 miles
Old Mar 15, 2006 | 11:25 PM
Kwikkordead's Avatar
Kwikkordead
I moved the thread to the '99-03 diesel forum.
Kwikkordead
You replaced your rear axle THREE times??? What are you using this truck for?
Old Mar 16, 2006 | 12:51 AM
Fordbronco69's Avatar
Fordbronco69
Infidel
You mean to say the seal on the axle leaked out all the oil and it destroyed 3 different axles?!?!?! I want to know who installed the seals/axles. If its the same guy over and over ide say thats your problem.
Did you check all your fuses? Was anything recently done to your truck prior to having problems with locks/cruise?
Old Mar 16, 2006 | 07:11 AM
ssssteak's Avatar
ssssteak
Truck is used to pull horse trailer- 5th wheel type but not so frequently- has only 62000 miles
Old Mar 16, 2006 | 07:38 AM
wolftan's Avatar
wolftan
Door locks may be the actuators...do those yourself...$1000 at the stealership for all 4! All i can say on the axles...WOW...that sucks!
Old Mar 16, 2006 | 10:26 AM
powerstroker27's Avatar
powerstroker27
I'm having a similar problem with my door locks but not the cruise. My locks act like they want to go up and down when I hit the button but the just sit there and twitch. If I hit the button enough times then my passenger side will lock/unlock but the drivers side just twitches. Also I have a beeping that goes on for 5 sets of 5 beeps and the quits. There isn't an idiot light on but I have noticed that the interior light, reverse lights, driving lights (in the bumper), and of course the door locks don't work. Is there a fuse that could controll most of these or do you think something else is wrong?
Old Mar 16, 2006 | 10:49 AM
Lushman's Avatar
Lushman
My firends 2002 F350 had a similiar problem with the door locks and had to replace all of the actuators. Luckily he had the extended warranty so it was covered by Ford. Is this a common problem? I just bought my 2000 F350 but just figured his was a freak incident?
Old Mar 16, 2006 | 11:05 AM
ssssteak's Avatar
ssssteak
door lock actuators
the price on the actuators installed went from $673 to $459 using the info from this site so thanks for this.Working on the axle problem
Old Mar 16, 2006 | 11:45 AM
Lushman's Avatar
Lushman
Was the $459 for all 4?
Old Mar 16, 2006 | 02:28 PM
redneckboy's Avatar
redneckboy
My door locks do the exact same thing. As far as the cruise control someone mentioned. They recalled the cruise control on 1998 through 2000 Ford Expeditions and I know the F-250's and pretty sure the 350's because some of them were catching on fire. You might want to go to year dealer and get that fixed cause if that is related they have to do it for free.
Old Mar 16, 2006 | 05:57 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
I changed out my front pass. side the other day. Actuator was $70.00 from the stealership. It took me 45 minutes and that was removing the lock assembly, now that I know how the actuator is attached you don't have to remove the whole assembly. Its worth doing it your self, just be patient.
Old Mar 17, 2006 | 05:26 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Thread moved to Super Duty forum
mjb196
Jun 2, 2009 07:53 PM
bob_m10
Electrical Systems/Wiring
Sep 14, 2008 01:15 PM
russrbins
Jul 11, 2007 01:52 AM
KAKER
Dec 4, 2005 08:02 PM
