Air plenum gasket
Old Mar 14, 2006 | 05:11 PM
Trailcat's Avatar
Trailcat
Air plenum gasket
Had a fun day of trying to replace a valve cover gasket, put the air plenum back on, started it up and it idled like I had it floored. Replaced the air plenum gasket and it idles close to the same, but now I have no power it seems. I have to floor it almost to get any power from the motor. Would this still be from a leak somehow? Its on a 93 F-150 with a the 5spd.
Old Mar 15, 2006 | 12:23 PM
optikal illushun's Avatar
optikal illushun
all the vacuum lines hooked up right on the tree? also did u replace the throttle body gasket and is the cables free and easy to move?
Old Mar 15, 2006 | 05:16 PM
rhetor's Avatar
rhetor
You sure you connected the PCV vacuum hose back? It is on the bottom side of the plenum and goes to the pcv on the back of the valve cover. Easy to forget, as its difficult to see.
I would have to agree with optikal, most likely a severe vacuum leak.
Old Mar 16, 2006 | 07:24 PM
924x2150's Avatar
924x2150
Me three! Busted plastic vac line. The plenum is hard to screw up.
A hand-operated vac-pump kit with gauge might help you find out where the leak is.
Edit I wonder is the truck almost OK? I wonder if the computer is still in shock from the original "over-revving" condition.
There is a chance that maybe it needs to be cleared by re-setting the CPU and let the engine find its correct mix. Kill the power for a few minutes and reset the computer.
Or pull the codes first, then reset the computer.
Old Mar 19, 2006 | 05:32 PM
Trailcat's Avatar
Trailcat
Thanks, and sorry for the long delay. It is working a whole lot better after I put the new gasket on. I will try clearing the cpu and let you know. Thanks again.
Old Mar 19, 2006 | 10:34 PM
optikal illushun
what new gasket? glad to hear all is well and life is good.
Sizemore0730
Dec 28, 2017 08:15 PM
SeaCarr
Apr 18, 2016 10:28 PM
hotrodfeguy
Oct 26, 2015 01:45 PM
EvinM
1997 - 2003 F150
Jan 2, 2007 02:52 PM
shawn2604
Sep 7, 2005 04:49 PM
