How do you change the upper intake plenum?
Old Sep 7, 2005 | 02:44 PM
shawn2604's Avatar
shawn2604
I have a 1990 Ford Bronco XLT with a 5.0L. The engine idles at 1800 RPMs when in park or nuetral all the time and at 1200 RPMs in gear. I have replaced the IAC, TPS, O2 sensor, MAP sensor, and cleaned the throttle body and it didn't make a difference. I was told by a mechanic he is 95% sure there is a vaccum leak at the upper intake plenum and to replace it. One question, how? How do I go about doing this? I bought a upper intake plenum gasket set and it came with 3 gaskets and an o-ring. Can somebody help me?
Thanks,
Shawn
Old Sep 7, 2005 | 03:31 PM
fitzwell's Avatar
fitzwell
disconnect all of the wiring to the upper unit. Remove the plate in the middle of the upper. remove 6 bolts, Lift & Separate, clean carefully( you might wish to clean the throttle plates at this time. if you do, use a throttle plate cleaner, NOT carb cleaner)Install the plenum chamber gasket wiht a THIN coat of coppercoat, torque to spec & drive
Old Sep 7, 2005 | 04:49 PM
Beast12's Avatar
Beast12
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State Chapters located near the bottom of the main forum page.
I moved your post to the 302 forum. You should get some more help and tips in here.
See ya on the boards!
-Matt
timellis
1983 - 2012 Ranger & B-Series
Mar 16, 2010 10:14 AM
wildcat99
May 15, 2007 01:47 AM
EvinM
1997 - 2003 F150
Jan 2, 2007 02:52 PM
JohnMMena
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 18, 2005 10:09 AM
