head questions
Old Mar 13, 2006 | 08:32 PM
7FORD2's Avatar
7FORD2
Question head questions
ya fellas i was wonderin if there is such a thing a hi rise heads for a 390? thanks
Dustin
Old Mar 13, 2006 | 08:37 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
No, but if you install them on a 4.05" bore valves will hit the cylinder walls, they are spaced farther apart as they are larger valves.
.....=o&o>.....
Old Mar 14, 2006 | 12:13 AM
rusty70f100's Avatar
rusty70f100
I think Barry has Blue Thunder heads that might work. They're listed as "High Riser small bore quench chamber." I dont know in what context "small bore" is over there though.
http://store.survivalmotorsports.com...0-427-428.html
Old Mar 14, 2006 | 09:03 AM
Barry_R's Avatar
Barry_R
Means 428 valve spacing. Those are actually proven better in testing than the "large bore" 427 valve spacing. I don't know about 390 bore clearance though - could still be a pretty big issue with any decent size valve - we use 2.200 intake and 1.65 exhaust - - not too big really. I'll have to try some on sometime to see what happens - might be OK on say a .060 over deal???? Or notch the bores like a 351C???
Old Mar 14, 2006 | 03:25 PM
rusty70f100
Please do test fit it and see what happens. If it works, I may be interested in a set for my 390 at some point down the road.
How do those high riser BT heads flow, anyway?
Old Mar 14, 2006 | 03:59 PM
Barry_R's Avatar
Barry_R
The high risers are good for at least another 20 cfm so far. If I had a legal cast high riser intake I'd have run them in Engine Masters. As is I'm gonna find a way to make them work next year - - a legal, though perhaps maybe slipperly way....
karlsd
Oct 18, 2002 02:02 AM
phantom429
Jul 29, 2002 12:13 PM
greenhighboy
Aug 15, 2001 06:45 AM
chaser
Jul 30, 2001 07:54 PM
cobrajet
Feb 10, 2001 03:16 PM
