460 hard start when warm
Old Mar 13, 2006 | 04:11 PM
kwheatcroft's Avatar
kwheatcroft
I have a 88' with a reman FI 460. When cold, it fires up right away, but after I run it up to operating temp, it won't fire very good. It cranks normal, but doesn't sound like it's getting good spark. I have a new cap, rotor, and bosch platinum plugs. I also replaced the manifold air temp sensor. The longer it sits and cools down, the easier it starts. It does it on both tanks, and the way it starts when it's cold, I don't think it's fuel related?
any ideas?
Kevin
Old Mar 13, 2006 | 10:13 PM
kermmydog's Avatar
kermmydog
I had this problem on an 86 F250 460. It drove me crazy. I replaced the module, the starter switch, fuel pump relay, mine wouldn't do it all the time sometimes it would start fine warm, and started cold all the time. One day I was at a friends house and he said open the hood he pulled the dist. cap and grabbed the rotor and it had way too much play, it was a new rebuilt dist. we changed it out and problem ended. That was two years ago. It might be worth a check.
Old Mar 13, 2006 | 11:12 PM
Bear 45/70's Avatar
Bear 45/70
What kind of play in the dist shaft, side to side or rotational?
Old Mar 14, 2006 | 07:37 AM
kwheatcroft
I will check out the dist but I don't think that it has excessive play. What do you guys think the possibility of the timing having anything to do with it? I read yesterday about a guy who had a hard warm start problem that was caused by timing and a stretched t chain. Everything is new (except dist) so it might to dist too. I forgot to mention that it idles too high also, especially when it's warm? It cranks and cranks, and sounds like the timing is off when it finally fires, kind of stumbles and then takes off. What is the correct way to time it? Warm, in park, spout out. Then do you shut it off and replace the spout, or put it in while it is still running? Also, do you need to disconnect the battery after you time it to let the computer re-set itself?
thanks for your help,
Kevin
DieselCamper
19
Aug 25, 2016 01:43 PM
05F250DSL
Jan 13, 2015 08:18 PM
460jared96
Oct 11, 2014 09:26 PM
yewdall
Apr 21, 2012 10:18 PM
old timer 4x4
31
May 25, 2006 07:39 AM
