hey does any one have injector install directions cause i wanna do my injectors tonight and i don't have a set of directions any help ius greatly appreciated +
no they dont i mean its prety self explanitory but i went and removed the injectors and gps and took the valve covers off. with out having any instructions that tell u the little tricks to get stuff out. i never knew how big these things are there HUGE
kwik your gonna have the fastest 550 in the country.
LOL, just the smoothest running one. I bought stockers with new nozzles.
This is a trailer pulling rig and even with air damaged, clattering injectors that only give me 180 hp at the wheels at the last dyno event I went to, I am still able to pull the 14,000 lb trailer up a 6% grade and only have to shift down once out of overdrive. And that's before loading in any power adding tune.
I figured that simply restoring the injectors to stock would be a big step up for me and would be more than I could ever use. My main goal is to be able to maintain WOT on a big hill and not have to back out due to excessive EGT's.
I was VERY tempted to get some big injectors, but I didn't want to take the chance on the EGT issue.
i know what you mean, i was only running on 4 cylinders on my truck. it got so bad i was losing one more a week. well even reworked ones are gonna be a big improvement.
i would think if you went to singles stage 1's your egt's would still be very controlable. and some single programming of course.
what do you think of having a pac nw get together and dyno day for fte folks?
That would be great, but in July or August so the weather will be warm.
