Ball joint labor time
Old Mar 19, 2006 | 05:00 PM
  #31
NewXer's Avatar
NewXer
Possibilities include the wheel bearings & seals. Check the rotors while you have them off.
Old Mar 19, 2006 | 05:46 PM
  #32
Coolstrategist's Avatar
Coolstrategist
Thanks. I will have them check/replace all of the above.
Old Mar 26, 2006 | 10:22 AM
  #33
NewXer's Avatar
NewXer
Well I finally got my rotors on Friday & did the deed yesterday. All 4 ball joints, all tierods, rotors, brake discs, & wheel bearings. I started at 8:30 am & finished at 6:30 pm.
Nothing too hard in the list... the huge C Clamp that I "borrowed" from Autozone worked great to press the ball joints in & out of axle knuckle, but perhaps the worst part was figuring out how to use the clamp.
Larry
Old Mar 26, 2006 | 10:35 AM
  #34
hink10's Avatar
hink10
Larry
Yeah, it took me a bit of thinking to use the press also.
Old Mar 29, 2006 | 05:12 PM
  #35
Forest's Avatar
Forest
Thanks for the tips on the clunking noise in front end. I replaced sway bar bushings. No help, even though I am sure they needed replacement. I still have a light knocking / clunking noise. I tried the ball joints by hand (moving tire, when jacked up, even kicking at tire, did not cause any motion or noise). Now, I am wondering about sway bar links and tie rod ends. Any thoughts?
Old Mar 29, 2006 | 08:22 PM
  #36
tjbeggs's Avatar
tjbeggs
yep could be your links. try unbolting the links and drive the truck with everything tried up out of the way and see if it clunks
Old Mar 31, 2006 | 04:36 PM
  #37
jake00's Avatar
jake00
Ford dealer quoted me 530 for 1 side 790 for both sides
Old Mar 31, 2006 | 05:14 PM
  #38
JMACC's Avatar
JMACC
Just Thought I would key in here-
I just posted a similar question on the superduty forum and I received a price of $1,350.00 from a local shop to replace the ball joints on my 2000 F350 CC LB PSD. I thought it was kind of high so I am going to tackle the install myself.
JMACC
sand_fiend
34
Jul 6, 2013 08:08 PM
5.4L to Freedom
Jan 17, 2011 08:13 AM
lottscreek
1997 - 2003 F150
Mar 22, 2010 08:56 AM
fast_fred
Apr 4, 2009 02:06 PM
spnrgy
Feb 13, 2005 05:39 PM
