Horn problems
Old Mar 12, 2006 | 02:44 PM
seafire's Avatar
seafire
Unhappy Horn problems
I have a 90 4x4 standard cab. I'm having problems with the horn. It just will not work. I found the wires that connect the two horns together. There is only on wire for both of the horns. I did not find a ground wire coming off any of the connections. I need to get this working. Can anybody help me
Thanks Seafire
Old Mar 12, 2006 | 06:17 PM
Rockledge's Avatar
Rockledge
The horns are grounded through their mounting bracket and the frame. There is no seperate ground wire.
Pull off the wire(s) and check for 12v when the horn is pressed. If you don't get 12v, then it's probably a fuse or relay. If you do get 12v, then either both horns are bad, or their grounds (rust, corrosion, etc. at the mounts) are no good.
Old Mar 13, 2006 | 08:54 AM
seafire's Avatar
seafire
horn problems
Thanks for the help. Do you know where the relay is located?
Thanks Seafire
Old Mar 13, 2006 | 09:17 AM
Rockledge's Avatar
Rockledge
Best I can do is with regard to a '92, ought to be the same setup, I would guess.
If your Ranger has crusie control, then it will indeed have a horn relay. The relay can be found behind the lower LH side of dash, RH side of steering column, mounted on a bracket.
If your truck does not have cruise control, then there is no relay in the horn circuit.
Duckmang
Jul 28, 2013 11:40 PM
seafire
Oct 25, 2009 03:10 PM
seafire
Oct 18, 2009 04:46 AM
seafire
May 14, 2008 02:40 PM
mcne
Electrical Systems/Wiring
Oct 13, 2005 09:37 PM
