Sponsored by: Real Truck
steering components/accident
Old Mar 11, 2006 | 02:56 PM
jasonschwenk's Avatar
jasonschwenk
i was in a side collosion accident and when it happened my steering wheel was 90 deg out
first now that i have extreme play in the steering wheel is it the steering box and how do i check this
second i was looking at the drag link (the one that goes from the pitman arm to the pass side wheel if i am wrong) looks bent. does this link supposed to have a slight bend about 8" from the pass side wheel?
thanks
jason
Old Mar 13, 2006 | 05:58 PM
jasonschwenk
bump!
anyone?
Old Mar 14, 2006 | 09:57 PM
Ronin007's Avatar
Ronin007
Jason - If I remember correctly the drag link is straight. I will check mine tomorrow as it is dark out right now. I can't comment on your steering box, but I know there are other things that will make your steering have play in it due to bent components. I will post up tomorrow when I have a chance to look at my drag link in the light.
Old Mar 15, 2006 | 04:22 AM
jasonschwenk
i am correct in calling it the drag link - from the pitman arm to the pass sid wheel area?
Old Mar 15, 2006 | 06:53 AM
DetailerDave's Avatar
DetailerDave
In my opinion only, of course: If you have a major problem with your steering, and you have to ask "how to check it", then I think you need to have someone qualified look at it and determine what is wrong. Your life (or someone else's) could depend on it.
Old Mar 15, 2006 | 04:01 PM
jasonschwenk
i don't have a major problem just like to do things myself
i', not asking how to check but rather what else i should look for
i'm sorry but did you learn everything you know from birth or did you ask questions!!!!
Old Mar 15, 2006 | 04:33 PM
RAMBOv10's Avatar
RAMBOv10
I checked on my 2003 4x4 and the drag link is not straight, it is straight until it gets to the passenger side and then it has two bends in it. Have you had someone move the steering wheel from side to side while you check for any play in the steering components under the truck?
Daniel
2003 F-250 V10 Sport CC 4X4 Long Bed
Old Mar 15, 2006 | 06:11 PM
jasonschwenk
no it's been to cold for my a$$ just trying to get my ducks in a row and find out everything i can before i jump in
anyone think it is a good idea to change tire rod ends or only if the have play-this would cause wandering correct?
Old Mar 15, 2006 | 07:34 PM
Ronin007's Avatar
Ronin007
Daniel stated it correctly. The drag link is straight from the pitman arm and then has a couple of bends just before it connects to the tie rod end on the passenger side. As to when to replace TRE's I would just do it if there is play or lack of smooth movement and yes a worn or damaged TRE would cause some pretty strange steering.
Old Mar 16, 2006 | 04:24 AM
jasonschwenk
thanks for the info
Old Mar 16, 2006 | 09:31 AM
EnviroCon's Avatar
EnviroCon
Sorry I didn't remember this before, but here is a pic from my gallery that shows the draglink, tie-rod, and most of the steering components from the pitman arm down.
Old Mar 16, 2006 | 07:15 PM
jasonschwenk
perfect thanks!!!!!!!!!
Tinbird83
Jul 10, 2014 11:45 AM
LSO1123
Jun 8, 2012 01:00 PM
v8only
Jun 23, 2011 08:58 PM
MADFord4X4
13
Aug 4, 2010 01:24 AM
Metdawg44
Jul 30, 2008 08:30 AM
