Offroad & 4x4
Winch vs. Lockers
Old Mar 13, 2006 | 06:50 PM
  #31
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
i would definitly lock it 1st, then save every dime until oyu can buy a winch
Old Mar 13, 2006 | 07:00 PM
  #32
RawPower's Avatar
RawPower
hills definately says lockers all over it... esp since itll be wet some. You will lose some mileage out of your tires, but IMO its worth it. Id do it if I had the money....
Old Mar 13, 2006 | 07:10 PM
  #33
rebocardo's Avatar
rebocardo
> where you see that? i need one for the trailer
www.northerntools.com
Item #14293
All the ones that look like this, are all made by the same Taiwan company, northern, ebay, etc.. I think I posted a while back about busting the shaft on mine when I made the mistake of skidding with the log attached. Snapped the gear shaft in 1/2. oops. So, I ended up learning about it in my quest for parts. Northern took it back and gave me credit towards a Warn1700 :-)
For what it is, it is a good value. I found it handy dragging 1200# logs into the truck bed and for getting cars on trailers and tow dollies. I used it to help pull down a few trees and skid a few logs too.
It is slow, has a manual clutch for unspooling, but, draws barely 40 amps at load which was perfect for my 65 amp F-100 alt. 6 guage wire worked swell. It will pull a full sized truck onto a trailer.
Old Mar 13, 2006 | 07:12 PM
  #34
ivanribic's Avatar
ivanribic
They're about $30 for the bases: http://offroadrecovery.zoovy.com/product/HLORB
Yeah, for what you're doing I think a locker (or 2) and a Hi-Lift would be a much better way to go.
bigred66
Apr 1, 2011 12:52 PM
YamakidCR500
Offroad & 4x4
24
Apr 2, 2009 11:57 PM
systemofadowntox
Offroad & 4x4
44
Apr 28, 2005 09:38 PM
1962_Fords_rule
Offroad & 4x4
41
May 18, 2004 09:12 AM
patsplace
Offroad & 4x4
20
Jan 3, 2004 01:53 PM
