20" or 18" wheel on FX4?
truck will not be higher. that depends on the tire diameter.
Which is better for offroading? that is a broad questoin. It really depends on what you want to do. 20" rims will help you keep your bead seated better, but 18" will give you a little bit better sidewall flex. Either way, there isnt enough difference between 18" and 20" rims to matter. Then it boils down to what tire and what size tire do you want to run? in reality, 17" rims are probably better bc they are becoming a lot more popular in the offroad world. replacing the crappy 16.5 cwoozy rims...
There aren't very many off-road tires over for 18" or 20" wheels, but 17" is starting to pick up. Selection may be better in a few years, though. I wanted to get 17" or 18" wheels and tires, but couldn't find a tire I liked, so got 16" wheels and tires instead. (I had 15" before) Of two tires with equal diameter, the one with a bigger wheel will often balance better, and this is one legitimate reason to get bigger wheels. Alas, most of the tires for them have very low ratios, so they only good in a mall krawler.
They all have the same section width. The Goodyear AT/S has the most agressive tread pattern out of the 3. The BFG will probably wear the best. Don't know much about the Pirelli performance. The 20" package will be more prone to rim / tire damage off road due to the smaller sidewall height.
Pirelli 20" diameter is approx. 31.89 in
Goodyear and BFG 18" diameter is approx. 32.09
Originally Posted by ramboss429
I personally step down from my factory 17" wheels to 16" wheels on all my new fords once the 17" tires are wore out.
Anything bigger than 16" is GHEY and should have never been put on a truck like monsterbaby has already said!
