Offroad & 4x4
Brake Troubles Offroad
Old Mar 7, 2006 | 05:14 PM
TokenGMguy's Avatar
TokenGMguy
Exclamation Brake Troubles Offroad
I have a newer model truck with 4 wheel anti-lock disc brakes. I have noticed that at times while driving off road, my brake pedal becomes very stiff and will not depress or slow the truck. When this happens I also get a grinding noise from the front of the truck. After a little pumping it stops and I get the wheels to stop spinning, but I have had one or two close calls, fortunately I was not following too close. I figure I am just getting some gunk in between the caliper and rotor, but if anyone thinks it is more serious please let me know.
Old Mar 9, 2006 | 09:46 AM
78250crewcab4x4's Avatar
78250crewcab4x4
what you have is ABS freaking out. yup that "safety system" can actually be pretty dangerous. Chevys are designed for the street, not off road.
Old Mar 9, 2006 | 11:07 AM
s8whiskey's Avatar
s8whiskey
If it does it again put the vehical in Nuetral and hit the breaks it should disable ABS system
Old Mar 9, 2006 | 11:51 AM
TokenGMguy's Avatar
TokenGMguy
Haha, alright, thanks guys.
Old Mar 9, 2006 | 01:21 PM
Pkupman82's Avatar
Pkupman82
I have had a few close calls with my 95 Jimmy on the ice because of the ABS screwing up. It quit working so now I have an ABS light on...oh well at least it stops better now.
Old Mar 9, 2006 | 03:51 PM
chrono4's Avatar
chrono4
my brothers exploder used to do that, clippped the abs sesor wires, no more abs, no more problem.
Old Mar 9, 2006 | 04:14 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
abs can be dangerous somtimes....try the neatral thing, if you liek it then disable it in some way
Old Mar 15, 2006 | 10:12 PM
Pacam's Avatar
Pacam
ABS off road
If you want to keep control of your vehicle off road you should very seriously consider adapting your trucks ABS system. The easiest thing you can do is to wire your ABS system via a dash mounted switch. When off road, turn off the ABS when you get back on pavement turn it back on. This will most probably save your life if you get into a stiuation where your ABS takes control while you slide off the road into God know where.
You can find posts about how to do this all over the net or go to your shop manual and look at the wiring. Most Fords have the ABS in the fuse box inside the engine compartment a simple jumper and your in control. By the way, use a switch with a light so you know the ABS is on you don't want to get into an accident on pavement due to switch positions.
Old Mar 15, 2006 | 10:57 PM
Pacam's Avatar
Pacam
ABS Again
Not all people who drive off road are good at it. Some are fools, some take stupid chances. I worked at a mine in the Sierra which was 14 miles from the highway. Had to drive this unimproved rut of a road everyday for three years regardless of the weather. Sometimes it was fun, most times it was not. Got to learn how to "process" when scared to death as the drop offs on this road were over 800 feet. When the snow is four feet high and ice is on the bottom and your the first one in for the day, it can be interesting.
I found a write up about ABS you might find helpful, it is written by a guy who was looking for a little fun and got his wish.
Go here:
http://www.4x4trailhunters.com/trail.php?id=17
Old Mar 21, 2006 | 12:02 PM
TokenGMguy's Avatar
TokenGMguy
Wow, that's a good idea with turning the abs off, I will definately look into it. For now I will make sure to maintain the safe following distance that I have been.
anthonyh75
Nov 15, 2016 08:54 AM
98SVTCobra
May 19, 2011 08:09 PM
troubledford
Oct 18, 2010 07:41 AM
Robert 17
Jul 3, 2008 12:07 AM
The67Beast
Jul 27, 2007 12:42 PM
