brake problems
Old Oct 16, 2010 | 08:18 PM
troubledford's Avatar
troubledford
brake problems
hello i am having problems with the brakes on my truck a 1984 ford f250 hoping you all can help pin point my problem
here is the problem i have good brakes most of the time but sometimes when i hit the brakes they feel hard and will hardly stop if i step on them hard the rear brakes lock up but here is where it gets odd i can let off brakes hit them again and stops fine i can not find any leaking fluid on any wheel master is full the front brakes are in good shape and stop fine untill it gets a wild hair my guess is ether a master cylinder or maybe the proportioning vavle the master has been painted so i am guessing its been replaced at some time
Old Oct 16, 2010 | 08:36 PM
Franklin2's Avatar
Franklin2
A hard pedal is a symptom of a booster or vacuum problem to the booster.
Old Oct 16, 2010 | 08:37 PM
mattthegreat's Avatar
mattthegreat
I had to redo the whole breaking system in my 85 f150, most of the parts were good that i replaced but I worked my way back to the master cylinder, my problem was (aside from rear right break being seized) the breaks would work or they wouldent and I would have to hit them a few times, they would faid when they did work and I was leiking break fluid about 250ml a day driveing to work and back (30min to 1hr total)
try replaceing the master cylinder, just be sure to bleed it properly, and bleed all the lines.
Old Oct 17, 2010 | 07:18 PM
troubledford
ok when i get paid next friday i will replace the master cylinder and the brake booster also i do know it is leaking vac alittle when i hit brakes so will replace both peices
thanks for the help
Old Oct 18, 2010 | 06:24 AM
Superred2's Avatar
Superred2
Can the power brake booster be rebuilt or do you have to buy a new one? I know they aren't much, but was just asking the question. I see O'reilly's has the booster for $79 and the master cylinder for $39.
Old Oct 18, 2010 | 07:41 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
No and they are typically less expensive as an assembled pair ...
-Enjoy
fh : )_~
truckfella
Modular V10 (6.8l)
17
Mar 16, 2020 11:59 AM
Amish65F100
38
May 25, 2017 11:10 AM
Mark_in_co
Feb 8, 2017 08:10 AM
cander06
Apr 16, 2015 12:08 PM
mattthegreat
16
Jan 17, 2010 04:27 PM
