Sponsored by: Kumho
1976 Ford 600 brake problems
Old Jun 13, 2008 | 11:03 AM
Robert 17's Avatar
Robert 17
Hi Everyone,
I have a 1976 Ford 600 truck and am having trouble with the brakes. When I apply the brakes the hydro vac activates the boost valve and allows the air pressure to boost, I can here the air as the intake hose is behind the drivers seat. When I take my foot off the brake the air is still giving boost (as I can here it) . When I stop the truck and open the bleed on one of the wheel cylinders there is brake fluid pressure as I can here the brakes release.
When start the truck and apply the brakes ...they work O.K. until the system pressures up and I have the same problem. It seems that the system won't depressure enough to allow the boost valve to fully close.
I would appreciate anyones input.
Thanks, Robert,
Old Jun 30, 2008 | 05:50 PM
fordfan28's Avatar
fordfan28
I also have a 76 F600 with probably the same setup. Without thinking this through (and given that I haven't completely learned about the hydro-vac inner-workings, etc.) One quick thought is to try to open the bleeder valve on the hydrovac unit itself. If that releases the pressure then it will split your search in 1/2 - from the there up to the master cylinder or from there out to the wheel cylinders. Just a quick thought. Let us know what you find.
Old Jul 2, 2008 | 09:47 PM
Ford_Six's Avatar
Ford_Six
Is it supposed to have some sort of filter over the inlet? If it is anything like the foam filters used in the mid-to late-70s truck brake boosters, it's probably deteriorated and might have jammed the valve.
Old Jul 3, 2008 | 12:07 AM
Robert 17's Avatar
Robert 17
I finally figured out what the problem was. I took the big drum apart (i didn't realize it contained a diaphram which activates the plunger or cylinder that provides the boost to the whole system). There was rust etc on the lip of the diaphram and as a result a leak ...and therefore a partial vacuum . I cleaned the drum, now everything works as it should.
Robert6401
Apr 16, 2018 02:32 AM
erniek70
Mar 14, 2016 05:54 PM
robert kelsey
Mar 10, 2016 10:28 AM
robert kelsey
Mar 8, 2016 11:16 PM
94FSuperDuty
Dec 3, 2005 11:15 PM
