Oil & Lubrication
It's about Engine Oil Use?
Old Mar 13, 2006 | 02:32 PM
ford390gashog's Avatar
ford390gashog
5w20 in the winter and heat of summer.
Old Mar 13, 2006 | 05:40 PM
1975Ford's Avatar
1975Ford
API rating chart http://www.aa1car.com/library/api_oilguide_2004.pdf
Ford Motorcraft oil 5W-20 http://www.motorcraft.com/products.do?item=15
Reduces friction
Minimize engine deposits and engine wear
Protects against high temperature oxidation and low temperature thickening, rust, corrosion and foaming
Old Mar 15, 2006 | 01:34 PM
1975Ford's Avatar
1975Ford
motor oil info http://www.bajajusa.com/oil%20not%20so%20slippery.htm
Here are some test data on different API rating oils from the Southwestern Institute. http://www.swri.edu/4org/d08/Abstracts/GasEng.pdf
API Engine Oil Classification API SJ http://www.infineum.com/information/api-passenger-sj-sl-2004.html
API Engine Oil Classification API Sl http://www.infineum.com/information/api-passenger-sj-sl-2004.html
API Engine Oil Classification API SM http://www.infineum.com/information/api-passenger-sm-2004.html
Oil Analysis http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=forum;f=1
-BUCK-
Old Apr 3, 2006 | 02:09 PM
1975Ford's Avatar
1975Ford
Oil filter magnet, seems like a good product http://www.filtermag.com/carcraft.pdf
http://www.filtermag.com/tech.php
mczarski
Modular V10 (6.8l)
48
Apr 17, 2021 10:46 AM
Howard1124
6.7L Power Stroke Diesel
13
Sep 15, 2017 10:57 AM
TomBrooklyn2
Jan 28, 2015 08:35 AM
Mike in PA
6.2L V8
Sep 15, 2010 12:19 AM
salchachi
Feb 18, 2006 10:09 AM
